Steer wheel emb mod (w/pics)
Hope that helps, disconnect negative at battery so you don't hear horn go off a million times, or worry bout air bag. Also, The plastic pins are long and glued, so the challenge is to uniformly lift the emblem out. It's hard not to bend it. Also difficult to not scratch up the other parts around it, especially when you're wedging 5 plastic knives in there. I eventually needed a mini screw driver anyway, because I kept snapping plastic.knives. It can be done , but patiently, working each side near a pin a little at a time....wedge knife to hold that position etc etc.
I did snap a pin and bend another. Clear epoxy still got her back in there nicely, so don't panic
