The more I look at these pictures,the more intrigued I become with what I am looking at.Am I right in thinking that the seal is still there and the metal part of the seal is badly damaged. That would explain the "groove" on the shaft. Is part of the indside bearing race bent back into the rolling elements and cage or is that part of the seal? I believe this is a two piece tapered roller bearing with the rolling elements and the cage carried by the inner race and press fit on the carrier ,and the outer cage press fit in the case.I was around power generation for many years and have seen numerous failed roller bearings,especially those used on pulleys on coal conveying systems. Someone help me out here.
