Taking care of a new Camry '07 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2011, 08:33 PM   #1 (permalink)
View smc733's Photo Gallery
Hi everyone,
In a week I will have my hands on a 2007, 1 owner Toyota Camry LE, I4, 42k miles.
I wanted to know what some of my first steps should be to keep this relatively immaculate car in good shape. My first thoughts were
-Oil/Filter (should I stick Toyota genuine or go Mobil 1? I heard the I4 can occasionally burn oil).
-Coolant (should I get a flush on this?)
-Trans fluid (Toyota fluid)
-Air filter/cabin air filter.
-Battery?
-Spark plugs (which kind)
-Get brakes/fluid inspected
-New wipers
What do you guys think?
smc733 is offline   Reply With Quote
Old 12-01-2011, 09:33 PM   #2 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
Gen5
sounds like a good car
oil: not quite sure... my 06 doesnt use a drop of oil and i use full synthetic 5w30 but i kno the gen 6 takes 5w20 or 0w20.... not sure if thats why they sometimes burn oil or not
coolant: i wouldnt touch til about 100k..... i would watch out for water pump failure though, that is common on the 2azfe; make sure u stick with toyota pink coolant
trans: its really up to u, people do it at different intervals anywhere from every 30k to never......; make sure toyota WS fluid is used
air filter/cabin filter: again really up to you, toyota is good but more expensive..... aftermarket purolator is fine and if u want something a little better i would go with beck/arnley or denso
battery: i would have it tested just to be safe (advance does it for free)..... honestly brand doesnt make much of a difference the main thing your looking for is warranty and cold cranking amps..... toyota's are easy on thier batteries so they will last a few years between changes
spark plugs: i would highly recommend NGK irridium plugs..... denso is good too.... originals are good to over 100k but it never hurts to change them before hand
brakes: get them checked just to be safe but again, toyota's are easy on thier brakes when good stuf is used.... if pads need replacement i HIGHLY recommend akebono
wipers: just check them for wear and drive it in the rain and see if you can see lol..... if replacement is needed i would highly recommend bosch icon or valeo 900 series
good luck with the new ride!
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 12-02-2011, 08:34 AM   #3 (permalink)
robtpren's Avatar
Gameroom cash: $114600
View robtpren's Photo Gallery
Gen6
Was this car purchsaed through a dealer of a private party? If through a Toyota dealer is a Certified Used car?
Depending on the above might dictate what should be checked. If from a private party you may want to take it to your local dealer for a once over to make sure all the necessary updates and maintenance have been done and the car is in good mechanical shape.
If it is a certiified used from a toyota dealer, it should have been gone through and any necessary items have been checked and or corrected.
Good Luck with your new ride.
robtpren is online now   Reply With Quote
Old 12-02-2011, 12:29 PM   #4 (permalink)
I bought it from a dealer, I will have them make sure they do the Transmission TSB before they hand it over, it is not certified though.
Old 12-02-2011, 01:12 PM   #5 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
Oil/filter... stick with ANY name brand full synthetic oil. Most name brand filters work well but the OE cost is the same. I tend to grab whatever filter is on sale... bosch, wix, napa, purolator, stp...
Exercise the dipstick regularly so that you can monitor oil consumption. Top off as needed throughout your interval.
Coolant... 5 years... definitely change it out. Use the Toyota coolant or an equivalent like Peak Global or Zerex Asian.
Trans fluid, manual or automatic? Regardless, change it out. Use the OE fluid or an equivalent that mentions the spec.
Air filter.. change it if it hasn't been changed. Can't beat the Toyota OE engine air filter.
Cabin filter... mine doesn't last 6 months because of the 'country location'. It fills up with pine needles, leaves, seeds, pollen, critters... and all the dirt/salt that they pave the winter roads with. OE is best but Fram/wix/purolator make cabin elements too. You can even just vacuum it out.
Spark plugs... good for 60k-100k+. Get double platinum or iridium/platinum plugs and check the gap before installing. Sparkplugs.com has a good PN/brand tool. You can buy the plugs at the dealer, online, or any autopart store.
Toyota batteries have served me well usually for about 6-7 years+. If it starts fine in the cold winter morning, KEEP IT. When you notice that cranking is strained(slow), then replace it with a name brand battery. I'm a fan of Diehard gold/platinum and Interstate megatrons. I dislike floptima batteries and other overhyped batteries.
Brake fluid... bleed it now and every 2-3 years using name brand quality DOT 4 or 5.1 fluid.
Brakes pads... make sure there is at least a 1/4" material. Any less means its service time. I tend to stick with non-OE pads like Hawk, EBC.... 42k miles should still be original pads but your location tends to have aggressive drivers.
Check the thread depth of the tires. By 42k, they should be recent.
Wipers... any type you like. I don't care for the newer overpriced blades. Wax your windshield!
Toss in a bottle or two of quality FI cleaner. Techron Concentrate(the expensive bottle), 3m, Redline SI1, or BG44k are some good ones.
Find a car wash with a rust inhibitor undercarriage rinse. Don't want it to turn into a rust monster like so many Toyotas do.
CPO or certified by the dealer means NOTHING. Stoopid useless worthless checklists that silly consumers pay more for.
If its under warranty, go through the ENTIRE TSB and recall list. Make sure that NONE of the known issues are ignored.
deadrx7conv is offline   Reply With Quote
Old 01-17-2012, 07:57 PM   #6 (permalink)
eighty5iv's Avatar
Gameroom cash: $296510
View eighty5iv's Photo Gallery
I think the manual stated we use DOT 3 for 07+ Camry. Is it okay to put DOT 4 into it?
07 Toyota Camry SE
2.4L I4 + TRD Dual Exhaust + K&N Air Filter + Interior LED Conversion
Retrofitted: Honda S2K AP1 + TSX-R 2.5" Lenses + Denso Slim Ballasts + Osram CBI D2S Bulbs + ZKW-R 3" Clear Turn Signal Lenses
eighty5iv is online now   Reply With Quote
Old 01-18-2012, 12:06 AM   #7 (permalink)
Gameroom cash: $156145
View Zmon's Photo Gallery
According to this,and this too, I assume so. I guess we can use DOT 3, 4, and 5.1 (NOT 5). I'd get some more research before taking my word on it though.
Zmon is online now   Reply With Quote
Old 01-18-2012, 12:28 AM   #8 (permalink)
eighty5iv's Avatar
Thanks. I've seen reports of people using them on older Gen Camrys but no one with reports on Gen6+ until that last post you showed me. I'll keep up with the research but Thanks for showing me those posts.
07 Toyota Camry SE
