My car is being so dangerous today. The steering wheel is squealing when I turn left or right and the gas pedal vibrates like hell. What's wrong with my car guys please help ASAP !!!!!
Can you give us a bit more information? The squealing could be a bad power steering pump, I've had a couple of cars with this problem. As for the vibration, when does it happen? On idle, or while driving?
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
Thks for quick reply, it's happen when driving. everthing was perfect yesterday. On this morning I noticed something wrong but not sure until I figured out.
Steering wheels don't squeal. They might squeak in the cold weather if there is some interior trim pieces rubbing.
If its a squeal, pop the hood and take a look. A belt could be slipping. The pump could be seized, low on fluid, or a wobbling PS bearing might be waiting to fail, and leave you stranded. Anything else sharing the same belt could make you think its a PS issue when it could be something else.
Or, you might have a low idle issue causing the problem.
The Following User Says Thank You to deadrx7conv For This Useful Post:
hi guys my car is camry 2007 and today the problem was gone by itself. It's really weird but I think I got air trapped in my steering wheel fluid. My friend opened the hood, checked the power steering fluid which is fine, revving gas pedal for a while and BRAVO !!!!! I WAS SAVED LOL ^-^
There is no way to get air entrained in the PS fluid if the proper level has been maintained.That is if someone hasn't opened something in the hydraulic circuit. That system operates at over 1000 psig so what you usually have is fluid leaking out.Have someone jack the front wheels off the pavement and then start your car and cylce the steering wheel lock to lock[don't hold it there] a few times. That will expell the air out of the system. Regards.
I think it's time for a new drive belt on this thing. If I ask you if you've ever had one done you'll most likely say no, right?
Another thing is water pumps like to leak coolant onto the belt of these cars and that will cause it also.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5 Cheers!
this from you on previous occasions/threads....
in this thread YOU started, you claimed to have let SOMEONE ELSE drive your car, and he or she wrecked it..although you have deleted YOUR thread, i vehemently REMEMBER YOU and your plight...why didn't YOU LISTEN to us back then..???
you HAVE BEEN TOLD numerous times what to do, but why do you persist in making up threads...do you think you will get different answers to your problems..???
this actually amounts to spamming the boards with useless crap over and over again....
