Maint. Require light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2011, 09:45 AM   #1 (permalink)
Cocolatte
cocoLatte's Avatar
View cocoLatte's Photo Gallery
Ok very very dumb question:
firstly the reason i am asking this is because I am not familiar with the GEN 6's behavior. My dad has a 2004 and whenever he needs maint. his light would stay on.
Recently, every time i turn on my car, the "Maint. Required" light blinks 5-6 times then remains off.
What might be the issue? I had my oil changed 2 months ago...and its only been 2000 miles since then.
The car performs fine. Does the maint light on the GEN 6 usually stay on like the GEN 5 or does it just blink? Thanks
- Cocolatte -
2010 Camry SE, I4
JBL System, HomeLink, Bluetooth
Blacked Out Rear Emblems, Roof Spoiler, TRD Badge, HIDs, JDM Style Window Visors
cocoLatte is offline   Reply With Quote
Old 12-08-2011, 09:51 AM   #2 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $325800
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
Sounds to me like the maitenance light wasn't reset.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is online now   Reply With Quote
Old 12-08-2011, 09:59 AM   #3 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
the maintenance lights are annoying and you have to manually reset them. typically you have to hold a button in for a couple seconds to clear it. they are "dumb" buttons that are just on a timer, nothing more to it than that. it would be nice if there was a sensor in the oil pan that would reset it for you, but that is not the case.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is online now   Reply With Quote
Old 12-08-2011, 11:18 AM   #4 (permalink)
Cocolatte
cocoLatte's Avatar
how can i reset it? Thanks!
- Cocolatte -
2010 Camry SE, I4
Old 12-08-2011, 11:38 AM   #5 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
with the key in the off position press and hold the trip odometer button with ur left finger.... then turn the key to the on position.... some lines will blink in the odometer then it will read 0 then stop pressing the button
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 12-08-2011, 06:57 PM   #6 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $151050
View hardtopte72's Photo Gallery
The blinking means you are at 4900 miles. At 4900 miles the MAINT REQD light will blink then go out. At 5000 miles it will remain solid.
Gen 6 is slightly different than Gen 5 and some other Toyotas Like 2005-2008 Corollas and 2004 and up Siennas to clear the light.
To Clear the light:
1. Change your oil and rotate your tires (as well as whatever other maintenance it needs)
2. Turn your car to the ON position.
3. Tap the Trip/Reset button on the dash until it reads TRIP A
4. Leaving it in the Trip A position turn the key to the OFF position
5. While the key is in the OFF position press and hold the Trip/Reset button
6. While pressing and holding the Trip/Reset button simultaneously turn the key to the ON position (DO NOT START THE CAR!)
7. You should now see 5 dashes across the Trip display that will go out one by one until you see 5 zeros. When you see 5 zeros the MAINT REQD light is reset.
8. Start your car. The MAINT REQD light should come on for a second and then go out.
Hope this helps
hardtopte72 is online now   Reply With Quote
The Following User Says Thank You to hardtopte72 For This Useful Post:
cocoLatte (12-09-2011)
Old 12-09-2011, 01:57 AM   #7 (permalink)
Cocolatte
cocoLatte's Avatar
^thanks!
- Cocolatte -
2010 Camry SE, I4
Old 05-09-2012, 02:54 PM   #8 (permalink)
View m5comp's Photo Gallery
I am having a similar problem with my 2004 Camry. I had the oil changed March 31, and when I cranked the car this afternoon, the "Maint. Required" light blinked twice then went out. I certainly have not driven the car 4900 miles since the oil was changed. Is the problem just that the light needs to be reset?
m5comp is offline   Reply With Quote
Old 05-09-2012, 03:56 PM   #9 (permalink)
Gameroom cash: $304355
First of all I believe it's 4500 miles not 4900. Second, the procedure for resetting the light is probably the same as the generation 6, but check your owner's manual first. There should be a procedure in there. If not, try the generation 6 procedure.
Mike
Old 05-09-2012, 04:30 PM   #10 (permalink)
View aagitch's Photo Gallery
I was wondering about this. MY 2010 has hit roughly 5000 miles since it's last oil change and the light hasn't come on at all. It does come on with the other lights when you first turn on the ignition during the tests. Can this feature be disabled by the dealer? I'm not the original owner so just wondering.
2010 Camry SE 2.5L-35% Front & 20% Rear, Hollandia 700 Series Comfort sunroof
aagitch is online now   Reply With Quote
