02 Camry..replacing Cat Converter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2011, 01:00 PM   #1 (permalink)
View DaJuice71's Photo Gallery
Gen5 02 Camry..replacing Cat Converter
Hello TN....need your help!!!!! I have an 4cyl 02 Camry LE and I'm getting an P0420 trouble code. I've changed Air/Fuel Ratio Sensor that comes off the front Cat Converter and the rear 02 Sensor that is off of the rear Cat and I'm still getting that code, so as a result I'm changing the front converter that comes off the exhaust manifold. Now my questions is:
#1. Do I have to put any type of compound or anti-sieze on the new gasket that goes over the cylinder head studs?
#2. Do I have to put any compound or anti-sieze on the O-Ring at the bottom of the front Cat. as well before I re-assemble everything?
DaJuice71 is offline   Reply With Quote
Old 12-16-2011, 03:43 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $166700
View leakyseals's Photo Gallery
Not 100% but would think no to the gaskets, too much heat. When you take it apart the answer will be clear. Anti seize on the bolts? maybe if you ever plan to do it again. Would you mind documenting the procedure? Thank you. Also reading about this problem part of the issue is the ECM is programed to trigger the P0420 catalyst efficiency CEL somewhere around 95%. There is a TSB where the cat is replaced along with a ECM reprogram to set the threshold lower. You may want to look into having the reprogram done.
leakyseals is online now   Reply With Quote
Old 12-16-2011, 05:23 PM   #3 (permalink)
What do TSB stand for? I will definitely look into the ECM reprogramming.
Old 12-16-2011, 05:50 PM   #4 (permalink)
leakyseals's Avatar
Technical Service Bulletin from the dealer. Could be a recall, repair, etc. The TSB I'm talking about is HERE
The Following 2 Users Say Thank You to leakyseals For This Useful Post:
DaJuice71 (01-07-2012), Donald E. George (01-19-2012)
Old 12-22-2011, 04:06 PM   #5 (permalink)
View melmar's Photo Gallery
DaJuice71, i have the same code and i will be replacing my cat converter soon. Where did you buy your cat converter? how much?
melmar is offline   Reply With Quote
Old 01-07-2012, 08:09 PM   #6 (permalink)
melmar
I apologize for taking so long to respond but I bought my cat. converter from a family friend who works at an auto shop for $291. but I found a site online that has the OE cat converter for $310. the site is discount catalytic converter.com and the part is east 40587.
Old 01-09-2012, 05:27 PM   #7 (permalink)
leakyseals's Avatar
I get a P0420 after a highway trip, turns off around town, so it still passes inspection. Considering cats are 90% good when the light goes on and easy to remove, going to try cleaning mine before I get caught with the light on at an inspection. Will report back how that goes, what I used, etc.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
Old 01-10-2012, 09:56 AM   #8 (permalink)
Did it fixed your check engine?
Old 01-18-2012, 11:34 PM   #9 (permalink)
melmar......yes it fixed my check engine light.....
Old 01-19-2012, 07:31 PM   #10 (permalink)
View 08SalsaMax's Photo Gallery
When you replaced your cat, did you reprogram the ECU?? Thanks
08SalsaMax is offline   Reply With Quote
Old 01-19-2012, 08:08 PM   #11 (permalink)
leakyseals's Avatar
Unless he went to Toyota, only Toyota has the Firmware.
Old 01-19-2012, 08:39 PM   #12 (permalink)
Is this really necessary? Do I need to take the camry to toyota to calibrate the ecu after installing the cat converter?
Old 01-20-2012, 02:30 PM   #13 (permalink)
leakyseals's Avatar
Some say it is. Some say the use of aftermarket cats will only last a few years. I am not sure if that's why. There are 2 "cat related" TSB's that reprogram the ecu. One for the 80k warranty cat replacement, one for a sulfur smell coming from the cat. The assumption for the cat replacement TSB is the emissions threshold is expanded, or made less sensitive for the CEL (example 80% vs 95%). Not clearly stated, so I cannot confirm.
What I can confirm is I have successfully taken off and cleaned the front cat on a 02 Camry I4 2AZ-FE experiencing a P0420. Out went the light. Because the light is so sensitive (95%) the cat cleans very easy at a car spraybooth. Needs 2 new gaskets. takes about 2 hours. Suggest trying that before buying a new cat.
Old 01-20-2012, 03:48 PM   #14 (permalink)
I pulled the trigger and bought a brand new Bosal cat converter from Rockauto.com. The fitment is terrible! The hole for the heat shield does not alligned to the converter. The o2 sensor hole on the converter is mis-alligned with the heat shield installed!
So, i called rockauto to get a RMA. Man, what a hassle! Rockauto is requesting pictures and they will contact Bosal. Now, I have to wait for days or weeks. I will never buy again from rockauto. I rather spend extra hundred dollars and buy OEM.
Old 01-20-2012, 03:52 PM   #15 (permalink)
leakyseals's Avatar
Never had a problem with rockauto. The Eastern is a good match. Regardless, should have fit. Hey now you get a chance to clean the old one and just return that one. If your interested I can give you assistance
