So I was replacing a wheel stud and while taking the caliper out, I accidentally unscrewed the brake fluid bolt and it drained a little bit of fluid out. I had to decompress the caliper to put the brake pads in.
everything was placed back the correct way, now the brake feels too spongy and I have to press the pedal all the way to stop the car. not feeling safe.
need a little help as I'm not sure what needs to be done here.. did I somehow get air in the system? the brake fluid cap was on the whole time. advise please.
You need to bleed the brakes to get the air out of the line. It's a two person job, one to bleed and the other to pump the brake pedal. You'll need more fluid to top off the resivoir after
did you unscrew the brake line bolt or the bleeder? If you unscrewed the brake line bolt, you definitely have air in the lines. Like Punks said, you will have to bleed the brakes to get the air out of the lines. It is a two person job if you don't have one of those one man bleeder kits.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
The Following User Says Thank You to LE05 For This Useful Post:
No doubt if you removed the banjo bolt or loosened the bleader, you have air in the system.
I just purchased a universal pressure bleeder system on Ebay for about $90, well worth the $$$. I think the 1 vehicle type is more like $35, basically a garden sprayer with a hose and a master cylinder fitting. The plastic bottle one man bleeder kits aren't worth the plastic they are made of, yet they make a good catch bottle for the pressure bleeder system.
^+1 on the motive power bleeder. I've even got specialty master cylinder caps that are far superior and seal better than those shitty ones that come with the kit. Never doing a two person brake bleeding job again!
