Originally Posted by coopns
02 Camry. I have the red (is it 5 year or 100k?). I drained the coolant over the summer twice and mixed with 50/50 (distilled water). I checked it the other day and it was low on the reserve tank. I don't see any drops/spills in the driveway. Could it be leaking out of the cap?
And, do I have to buy the coolant at the dealer or is there an alternative at AutoZone/Napa?
Thanks.
02 I4 XLE 181k - I get that too. IMO think its the large under-filled overflow tank causing evaporation. The coolant comes in contact with a large air cavity which is not sealed. As the hot coolant enters the cold tank, condensation, evaporation out the exhaust valve.
Why I think this - At first I was scared it was a HG, a UOA confirmed this was not the case. Decided to ignore the full lines on the tank and went to 90% full, eliminating most of the air from the tank. Has not moved in over a year. Have a 00 Corolla with a huge tank and a fill line near top of tank. That one doesn't experience a drop, which confirms its not a red coolant issue. a coolant test after a year showed less water, more coolant.
From what I've read the red coolant or pink should be used only for the best long term results. Main reasons are corrosion related to the aluminum engine and radiator which can cause problems with sensors, etc. Is that true? Don't want to find out. I do know mixing red with green is a very bad thing. Gels into an orange goo. Other than the inconvenience of traveling to the dealer, its not that expensive once the red concentrate is mixed 50/50.
Book says change at 60k (i think). I just purge a gallon from the radiator every other year, its so easy and cheap, why not. So far water pump, hoses, thermostat, everything original. I probably jinxed myself sayin that.
