Camry TRD install question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2011, 04:50 PM   #1 (permalink)
Rey
Pilot0617's Avatar
Gameroom cash: $148000
View Pilot0617's Photo Gallery
So I installed my springs yesterday and my question is, Do i have to cut the bumstop? Because i can fell a clunking and hear it every time the front ends drops more than normal. I did surch on the DIY section but there was only one answer from a member.
09 Camry Full Gen 6.5 conversion/4300K HID low beams/3000K HID Fogs/Borla exhaust/ 35 tint all around/Auto folding mirrors/Full led conversion/ K&N drop in filter/ Flux capacitor to make it go faster.
Pilot0617 is offline   Reply With Quote
Old 12-20-2011, 05:03 PM   #2 (permalink)
Gameroom cash: $418500
View tengiday's Photo Gallery
My dealer installed the TRD springs for me, and I don't think they cut anything!
2008 Toyota Camry LE I4 - Modifications as if they come with the car.
- TRD wheels, TRD suspensions
- OEM replica navigation with iGo/Tomtom/...
- Folding LED signal side mirrors with JDM control switch
- HID retrofit headlights with S2000 projectors and Denso ballasts, fog lights
tengiday is offline   Reply With Quote
Old 12-20-2011, 05:50 PM   #3 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
you shouldn't be cutting anything. check that everything is tight, some bolt somewhere may be loose, especially the end links. did you orient the strut mount and the spring insulator correctly? it is supposed to go on a certain way, if it's not oriented correctly it could certainly cause a clunking sound.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 12-20-2011, 06:29 PM   #4 (permalink)
Rey
Pilot0617's Avatar
Thanks i think i did not oriented correctly so i will take it apart and see if i made a mistake.
Old 12-20-2011, 07:33 PM   #5 (permalink)
there should be marks or arrows on both the strut mount and the spring insulator... those arrows point out from the car, in line with the knuckle mount.
2005 Camry "LE"
Old 12-21-2011, 06:11 PM   #6 (permalink)
Rey
Pilot0617's Avatar
Uploaded with ImageShack.us
Wich side does the bearing mount on? Like these?
Old 12-27-2011, 11:50 PM   #7 (permalink)
View CDuBDolla's Photo Gallery
Anyway you can PM me pictures of your car. Your setup is identical to my situation. Just bought an 08 LE and i want to put the trd springs with trd wheels.
CDuBDolla is offline   Reply With Quote
Old 12-28-2011, 10:11 AM   #8 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
DO NOT cut the bumpstops, they're designed to prevent bottoming out.
Also, grease your springs with white lithium grease to get rid of the noises, it WILL make more noises in the future, so make sure u soak those springs in WLG. Just spray and rub the coils with ur hands (use gloves of course).
GT-R is online now   Reply With Quote
Old 01-01-2012, 12:58 AM   #9 (permalink)
roaming south fl
View smokeSIX's Photo Gallery
i had the same clunking when i did mine a few months ago.. i did a combination of clocking that piece you have pictured above(mine had blue marks from factory that you could see in the engine bay. they were pointing toward each other, i turned them to face toward the cabin of the car) and making sure i put the same pressure on the strut where it connects to the knuckle assembly(the 2 big i think 22mm bolts)..im not 100% but think they use this adjustment for camber.. i had to pull everything apart and reassemble a few times to eliminate this noise.
the noise is causes by the spring binding..have someone turn the wheel while you look up under it and youll see the coils of the spring get really tight right before the noise is emitted..
take more pics and i can describe more what i did to eliminate the clunking.. you will need an alignment after the install..mine pulls to the right but its only noticeable if you take your hand off the wheel for a second..
smokeSIX is offline   Reply With Quote
Old 01-16-2012, 04:16 PM   #10 (permalink)
Rey
Pilot0617's Avatar
Can you tell me what side does the strut bearing go on? Like the pic or the other way around?
