background:
2004 Solara, 135k miles. Its in pretty good shape, but has had an awful hum for the last thousands of miles. I did the left drift TSB a while back on my own (rotate the spring seat 2cm) and it did fix it for a while, but it never fixed the noise. I finally broke down and bought bearings and front axles. I bought the harbor freight tool used to pull them out and seat them and did that job. Now the wheels are quiet....but it came at a price. I think the vibration wore out the inner tie rod ball joint on the passenger side (the worse of the two front bearings). There is a steering clunk that you can here with the slightest actuation of the steering wheel. It appears to be the inner tie rod...
. I suppose the bad bearing masked and caused the problem. It used to vibrate so bad, you could make your hand go numb....and now insert a joke about "the stranger" here...
questions:
If I buy the inner tie rod tool that fits over the rod, is this an effective way of replacing the rod without removing the steering rack? Has anyone done this? Is it bad to torque on the rack arms to take the rod out and is it hard to get the boot parts back on? I can do this all myself, but if its a hassle to fit stuff together, I might take this one to a shop that does it without steering rack removal.
This is the tool:
http://www.harborfreight.com/inner-t...set-96558.html
here are videos of its use on other cars:
Is this a diy or run away, very far away?
Do both sides if I go to the trouble for one?
Replace the outer tie rods while I'm at it?
fwiw, I hate the bearing tool. The cups it comes with are the only value. If you have a press, buy the bearing tool for use with it, that would work much better. It works in this form, but its a lot more work to twist the bolt for enough force to bring it out and you will end up removing the knuckle to use it properly.
http://www.harborfreight.com/fwd-fro...ers-66829.html
advice? anyone done this one?
thanks
J
