Transmission Oil Level Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2011, 10:49 AM   #1 (permalink)
07 Camry I4
kaashifv's Avatar
Gameroom cash: $196930
View kaashifv's Photo Gallery
Gen6 Transmission Oil Level Issue
Hello All,
I have done a search and haven't come to a solution for this particular issue. Firstly I have a I4 2007 Camry LE with 102,000km.
I just did a drain a fill on the transmission (I didn't check the level before draining, but i should have). While draining I did measure how much fluid came out and it was roughly under 3 Liters.
I refilled exactly 3 Liters. Checked the level and it was aboce the HOT mark. I though i filled up too much but after driving the car for 10-15 mins i brought it back on full level ground, ran it through the gears and checked the fluid level, the level dropped down to the COOL reading. To be certain i left the car on level ground all night, checked in the morning and sure enough the level jumped back to above the HOT mark on the dipstick.
I have checked every day since the change and every-time I check the level when warm it shows around the COOL marking on the dipstick. Does this mean that my oil level is low?
This is the first drain and fill i did on the car, and as I mentioned i replaced the exact amount that came out.
Any advice?
kaashifv is offline   Reply With Quote
Old 12-30-2011, 01:24 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
Sounds like the fluid level with the car off. As if its overfilled. You may have forgot. After a fluid drain it takes a few miles for the new fluid to circulate, readings may seem high initially. When you get home or after going somewhere leave the car running, check the level. Add accordingly. Don't worry if its off a little bit. 1/4" under may be good, its winter up there.
Over the years I have learned how to check the tranny fluid same way I check the oil - cold and off. Once I get the level right using hot running, I measure the difference between that level and the level cold off. Not recommending it, but its possible.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
The Following User Says Thank You to leakyseals For This Useful Post:
kaashifv (12-30-2011)
Old 12-30-2011, 08:20 PM   #3 (permalink)
07 Camry I4
kaashifv's Avatar
Thanks for the reply. I will keep a close eye on it and will keep it in mind for the next drain and fill.
