eBay Fog Lamps for a 2007 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2012, 06:42 PM   #1 (permalink)
View 02CamryDesertSand's Photo Gallery
I have a 2007 camry LE that I want to install fog lamps in. Anyone recommend a set off ebay that are plug and play?
I'm not looking to cut the bumper to get the fog lights to fit.
thanks
02CamryDesertSand is offline   Reply With Quote
Old 01-01-2012, 07:36 PM   #2 (permalink)
Billiam's Avatar
Gameroom cash: $204125
View Billiam's Photo Gallery
I can comment on this as I have 2 ebay kits for each of our cars...and the Yaris and the Camry share the same lamp....just the bezel that surrounds it is different. Regardless of the name on on the box, they're all the same. The actual lamps bolt in just like the stock ones. They all come with the same prewired 4-pole harrness with some sort of switch that looks kinda stock.
As for "plug and play"? Eh, sort of...at best. On YairsWorld there are some DIY threads that show quasi-oem installs that are about as close to OEM as you can get. So I'm sure there is info, either here on TN or on a dedicated Camry forum, that would give similar installs. Regardless of how you do it, it'll probably require at least a bit of modding of the harrness. That may or may not be a big deal depending on your experience.
For me...I just removed all of the wiring related to the switch and ran the relay trigger wire to the parking lamp circuit. That way the fogs come on with the parking lamps and the low/high beams.
I'm happy with them...especially for price. Here are pix of both.
If you want to enjoy your car....stay off the internet.
Billiam is offline   Reply With Quote
The Following User Says Thank You to Billiam For This Useful Post:
02CamryDesertSand (01-05-2012)
Old 01-01-2012, 08:34 PM   #3 (permalink)
Billiam, both your vehicles look like they came from Toyota with the fogs installed on them already, they look great.
Thanks for the info. I guess I'll just grab a $60 set of fogs off ebay and get them installed.
Thanks
Old 01-01-2012, 10:19 PM   #4 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $149450
View hardtopte72's Photo Gallery
From what I have seen is to buy the ebay fogs and simply switch the bezels to the OEM Toyota bezels. They are only 13 bucks a piece and of significantly better quality. I bought a kit and it appears to be what I have.
As for wiring I wired into the low beam circuit with an add a fuse.
Looks OEM
hardtopte72 is offline   Reply With Quote
The Following 3 Users Say Thank You to hardtopte72 For This Useful Post:
02CamryDesertSand (01-05-2012), 09YotaLE (01-14-2012), Project07Macry (01-19-2012)
Old 01-01-2012, 10:33 PM   #5 (permalink)
Are you saying, buy the lights from ebay and get the bezels from the dealer? Then throw the ebay bezels in the garbage?
The Following User Says Thank You to 02CamryDesertSand For This Useful Post:
Old 01-05-2012, 03:53 AM   #6 (permalink)
Toyota Fanatic
Exactly what I am saying.
The Following User Says Thank You to hardtopte72 For This Useful Post:
Old 01-05-2012, 02:07 PM   #7 (permalink)
Thanks
Old 01-05-2012, 03:53 PM   #8 (permalink)
Toyota Fanatic
You should hit the thanks button on my post.
Old 01-05-2012, 03:57 PM   #9 (permalink)
Well since you twisted my arm...
Old 01-05-2012, 05:03 PM   #10 (permalink)
Billiam's Avatar
For what it's worth...the blue car has the aftermarket bezels. The red one has OEM. The only reason it has the OEM's is because Toyota made a front fascia change to the '09+ Liftback model. 2 years ago when the fogs were installed there was no aftermarket bezel available.
Old 01-05-2012, 08:12 PM   #11 (permalink)
Toyota Fanatic
Those Yaris fog bezels look a lot harder to mess up quality wise. On the Camry bezel it can easily be made too thin and break or fly off as it has a big indent and lines in it.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post .
Old 01-06-2012, 03:13 PM   #12 (permalink)
View paplu's Photo Gallery
thanks
I recently installed fogs on my 2010 camry.
I would recommend is buy a OEM factory fog light kit. I bought it off ebay for $155. the seller is "Daytonatoyota" Everything just fits in place and you get everything from Toyota (switch , relays...).
The kit came with instructions and fogs integrate with your low beams just like the factory ones.
I can post some pictures if you would like to see.
paplu is offline   Reply With Quote
Old 01-06-2012, 03:16 PM   #13 (permalink)
paplu, PIX would be nice, also see if you can post a link to the ebay page.
Old 01-09-2012, 12:32 PM   #14 (permalink)
Here is the link for the fogs.
http://www.ebay.com/itm/10-2011-Toyo...item53eadad6c0
Pictures comming soon!
The Following User Says Thank You to paplu For This Useful Post:
02CamryDesertSand (01-09-2012)
Old 01-09-2012, 12:37 PM   #15 (permalink)
Help!
How do i add an image?
Thanks!
