Originally Posted by igbeserk
sorry for hopping on this post. my car is giving me the vehicle speed sensor error code p0500. so the code has to do with the sensors in the tires? and just have to determine which one it is? my battery cable and post are clean very well taken care of. i've been getting intermittent issues lately where the brake, vsc, tcs, abs lights will come on and stay on. sometimes the check engine and airbags will do the same. sometimes powering it off and powering it back on helps. sometimes i have to drive with them on for a while then cut off and cut it back on. it'll go away.
so i'm at a loss was looking online for where the actual sensors are but if they're in the tires then i'll check to see what's going on there. maybe best to replace all the sensors. i dunno.
First the sensors in the tires are fo air pressure and temperature, not speed.
A code P0500 is "Vehicle Speed Sensor "A""
The speed sensors detect the wheel speed and send the appropriate signals to the skid control ECU. (ECU is the processing control computer module.)
The skid control ECU converts these wheel speed signals into a 4-pulse signal and outputs it to the TCM via the combination meter. (TCM is the transmission control module / computer.)
The TCM determines the vehicle speed based on the frequency of these pulse signals.
When a code P0500 is detected the following conditions must be meet;
When the ECT sensor is normal and the counter gear speed is 300 rpm or more, the vehicle speed signal is not input for 2 seconds or more.(the ECT and CS sensor is inside the transmission.)
Trouble Area;
Open or short in vehicle speed signal circuit,
Combination meter,
Vehicle speed sensor (Brake control system),
Skid control ECU (Brake control system)
TCM (Transmission Control Module)
Monitor Description
The TCM assumes that the vehicle is being driven when the transmission counter gear indicates more than 300 rpm and over 30 seconds have passed since the park/neutral position switch was turned off. If there is no vehicle speed signal with these conditions satisfied, the TCM concludes that there is a vehicle speed signal malfunction. The TCM will turn on the MIL and a DTC will be set.
You indicated the following problem;
"I have a 2007 Toyota Camry that has intermittent instrument cluster problems." (Intermittent problems are very hard to locate. If it don't act up during the diagnostic time it will not be broken.)
"The Speedometer and Tachometer will cease to indicate proper readings and drop to zero. The tachometer will then bounce between zero and what I can only assume is a close approximation of the actual engine RPM." (This is a very good clue to pass on to the service department as it will help a good tech determine the suspect component.)
At the same time, the ABS and parking BRAKE warning lights illuminate and stay on for the duration of the "episode". These last anywhere from 10 seconds to 10 minutes. (Cause and effect here...)
In the meantime, the car runs normally from what I can discern. I can be driving down the highway at 70 or sitting in the parking lot idling and these episodes occur. There are no other indications that something is amiss...no rough idling, no engine stalling, just the display. (You may have identified the problem here. The multiple power sources that feed the combination meter may be of suspect.)
This is a 2007 Toyota Camry, 4 cyl, 5 spd automatic. I have inspected the transaxle input and output shaft sensors and they appear to be in good working order. There are no indications of oil buildup or broken/shorted wires. Connections all look good from what I can tell. (The transaxle input and output shaft sensors are inside the transmission and are only accessible from the plug to the TCM or tearing apart the transmission.)
Test Procedure
READ VALUE USING TECHSTREAM (VEHICLE SPEED)
(a) Drive the vehicle and check whether the operation of the speedometer in the combination meter assembly is normal.
HINT: The vehicle speed sensor is operating normally if the speedometer reading is normal.
If the speedometer does not operate, check it by following the procedure described for a speedometer malfunction.
(b) Connect the Techstream to the DLC3.
(c) Turn the ignition switch to ON.
(d) Turn the Techstream on.
(e) Enter the following menus: Powertrain / ECT / Data List / Vehicle Speed.
(f) Drive the vehicle.
(g) Read the value displayed on the Techstream.
OK:
Vehicle speeds displayed on tester and speedometer display are equal.
NG>CHECK COMBINATION METER ASSEMBLY (SPD SIGNAL WAVEFORM)
OK>SYMPTOM SIMULATION AND DTC CHECK
It will be at this point if the system is working "normally" there will be no problems to fix...
The green highlighted items coupled with what you described about the Tach and speedometer actions will tell the tech where to start looking.
The more information you can describe about the symptoms the faster the repair will proceed, provided the Service Adviser, translates / writes it down properly AND the Service Tech understands those description(s).
I wish you luck in the speedy correction of this problem.
Please post the correction, when completed.
(Have you tried "Ghost-busters" or an "exorcism"?) (JK)
I know what you are (or will be) going through, as I have an intermittent "Shift Flair" between 2nd. and 3rd. that has not been found for 29,000 miles and who knows how many trips for the repair...
