Motor/Engine Mount - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2012, 05:36 PM   #1 (permalink)
View SilverCamry10's Photo Gallery
Motor/Engine Mount
I am creating a new thread here, because after searching for over an hour, I am unable to find anything that is comparable to what I am hearing. Maybe it is because I am a newbie, but I am not sure. I have a 2010 Toyota Camry SE with just under 51,000 miles on it. Every time I put the car into reverse and accelerate to apprx. 2-4 MPH then apply the brakes, I hear a loud popping noise, and it sounds like it is coming from the passenger front wheel. Slight noise from the drivers front as well. This doesn't happen in Drive, only in reverse at a low rate of speed. Any expertise or comments would be greatly appreciated. My father and I have taken the front wheels off and tested it, seems to be a motor mount, curious if this seems rational or common in a newer car.
Thanks for the help
SilverCamry10 is offline   Reply With Quote
Old 01-02-2012, 07:49 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
Could be THIS and your only hearing it in reverse. The sound is at 53 seconds into video.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-02-2012, 07:51 PM   #3 (permalink)
View Nums's Photo Gallery
leakyseals beat me to it, but the video is referenced from here: I hear a clunk sound when I first start driving on my 2010 camry
Nums is offline   Reply With Quote
Old 01-02-2012, 07:56 PM   #4 (permalink)
leakyseals's Avatar
I forgot it was a sticky, googled for it and ended up on YouTube. Its better to read the entire thread. Good call Nums.
Old 01-02-2012, 08:02 PM   #5 (permalink)
Similar, but not so sure..
It does sound similar to what I am hearing, i am just worried there is more to it than that. I may just be paranoid after reading about similar stories and there being a problem with the motor mount. The engine seems to twist quite a bit when we hear the clunk. We had it on jack stands and had the wheels off to troubleshoot it, and there seems to be an awful lot of twist to the motor. We have yet to hold the brake and accelerate to test it, though. I may just run in and have it thoroughly checked to be sure, may be a wise $50 investment. Hopefully.
Old 01-02-2012, 08:06 PM   #6 (permalink)
also.
It only occurs when I am slowly moving in reverse, and i press the brakes, whenever I do that combination, not only when the car is first started. After watching the video for about the 10th time, I'm pretty sure it isn't the self check. If only it were that simple...
Old 01-02-2012, 08:25 PM   #7 (permalink)
leakyseals's Avatar
Been through and replaced bad motor mounts. The whole car interior vibrates continually. All engines twist some under torque, normal for some play in a rubber motor mount. Though 53k and 2010 year is premature, aggressive driving, acceleration, etc. can tear the rubber or damage the supporting hardware. IMO some cars are known to go through motor mounts. The Camry is not one of them.
Old 01-03-2012, 06:42 AM   #8 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
the only true and tried way to check for a bad motor mount is this...
raise the hood
have another person looking under the hood
put the foot brakes on and keep pressure on the brake pedal.
put the car into drive, and VERY LIGHTLY touch the gas pedal.
if the engine "jumps out" of the engine bay..??? THAT motor mount is bad
next, same test
foot on brake
put car in reverse
VERY LIGHTLY step on gas
if the engine jumps out of the engine bay..??
that mount is bad...
at 50,000 miles, NO motor mount on any car, front wheel drive or rear wheel drive, should ever be bad as to allow an engine to jump out of the engine bay, unless VERY HEAVY gas pedal usage from a starting line is being done on a daily basis, you know...racing...????
Glenn8963 is offline   Reply With Quote
The Following User Says Thank You to Glenn8963 For This Useful Post:
SilverCamry10 (01-03-2012)
Old 01-03-2012, 02:14 PM   #9 (permalink)
View C11Red's Photo Gallery
Try checking your brake hardware for movement I have seen that make the kind of noise you are asking about most time its not a problem just play in the brake pads
C11Red is online now   Reply With Quote
Old 01-03-2012, 06:11 PM   #10 (permalink)
Stella
Gameroom cash: $135500
View SoUtHsIde_ChI's Photo Gallery
This is a common occurrence and is normal. The metal clanking is from the caliper and slide pins on the caliper having play between the two of them. Once the brake is applied they tighten up and their good to go. It is nothing to be concerned about. If you go to the dealership they will tell you it normal. I have replaced one at the dealership for this same problem. When the job was finished it still had the same sound. I feel it is a flaw in design. But still the car is safe to drive.
2011 Camry SE_
SoUtHsIde_ChI is offline   Reply With Quote
Old 01-03-2012, 08:35 PM   #11 (permalink)
Thanks Guys
Thanks for all the feedback, I am going to test the brake/ acceleration like you suggested, and will report back my findings. I think my girlfriend has a lead foot, but she definitely isn't a drag racer! At least I hope not
Old 01-04-2012, 01:17 PM   #12 (permalink)
View rule62's Photo Gallery
I heard the same noise as the original poster and this was the cause. I noticed it most when I was backing out of my garage/driveway. I had the dealership perform a TSB concerning vibration during braking, which involves resurfacing rotors and replacing pads. The noise is now gone. Take a good look at your calipers/pads and make sure everything is in order.
rule62 is offline   Reply With Quote
