2002 Camry 4 cyl Tranny Issues
I did a search on the CEL P0770 and P0765 codes and I find plenty in regards to the light on but every post I have seen, says the tranny is working fine. Not the case with mine. Tranny is slipping, and if you let it sit for 30 mins or so, it will run fine then start surging and slipping. Got to where I couldnt get it to move at all. It says B, D E trans shift solenoid for the codes. I dont want to put in this new solenoid and have not fix the issue. Is my tranny toast? Seems electrical since it will work fine once it sits for a bit. Plus, with the OD disengaged, it seemed to work fine, but even then it was acting up? I bought it used with 140k and dont know if tranny was serviced or not. I think it has due to lots of oil change receipts etc from the past 4 years.. Any help is apppreciated..
Thanks
ls
