Strange noise when engine is cold? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2012, 08:00 AM   #1 (permalink)
View crystalmyth's Photo Gallery
I drive a 2005 Camry SE. In the mornings, when I start it up for the first time, my engine almost...growls. That's the only word I can think of. Not even growl. But instead of purring like a kitten, it purrs like a tiger (walrus? LOL). And it's only when I first back it out and then take off. Once it's good and warmed up, it drives and sounds perfectly. Shifts beautifully.
And this morning, I let it warm up for awhile and it didn't make any noise when I took off.
I talked to my coworker about it and she said she had a similar issue with her 2004 Saturn Vue and it was something about a manifold, but couldn't remember what it was called. And she said her mechanic was able to fix it, but only temporarily and then told her it would cost her big bucks to fix it permanently.
So what am I looking at here? I can't take it anywhere because it won't make the noise when I get there, LOL.
crystalmyth is offline   Reply With Quote
Old 01-04-2012, 08:43 AM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
I see your in Germany. Assume its getting cold there. When was the last oil change? What oil do you use (include synthetic or conventional ) and what weight?
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-04-2012, 09:38 AM   #3 (permalink)
Whoops! Not in Germany anymore - need to change that, lol. I'm actually in the states living in Georgia. It's currently around 25-30 in the mornings. I'm coming up on needing an oil change (last one was November 5th) according to my sticker, but the car doesn't start harassing me until 4,500 miles, then it gets really stern at 5,000 (by way of the service engine light).
I'm using 5W-30 - do I need to bump it up to 10W-30 for the winter months?
Old 01-04-2012, 10:28 AM   #4 (permalink)
leakyseals's Avatar
No. Oils are thickest when they are cold, so you want thinner for winter. Will make it tick even worse with a 10w..The problem is quick lubes use inferior oils, inferior filters that slowly contaminate your engine over time. hence the early morning cold tick. Use synthetic oil and you can go 6-7k no problem.
The alternate if you have to use a lube shop and don't want to pay the full synthetic or the blend price: check the oil and when there is room put a pint bottle of Marvel Mystery Oil in with the current oil. This will thin the oil out in winter months, give the engine a mild clean. Marvel Mystery Oil can be found anywhere oil is sold. Do this only once per OC
Old 01-04-2012, 10:47 AM   #5 (permalink)
2009 Camry SE I4 MGM
glenn14's Avatar
Gameroom cash: $337725
View glenn14's Photo Gallery
You have to remember also your oil is sitting in the oil pan over night, it was 3 degrees here with a wind chill of -15 degrees in Mass, my engine ticks until the oil gets up into the top if the motor, once warmed up its fine, oil thickens in the cold weather !!! Thats why you need to run a thinner oil !!
Glenn
2009 Camry SE MODS:
Blacked Out Headlights with MDX D2S Retrofit,TSX-R Clear Lens, 85122+D2S Bulbs, G2 Red Painted Calipers, W.T.Floor Liners, Rosen Navi. GEN6.5 Chrome Wheels, XD Digital 35 watt ballasts, H11 Wire Harness, Megan fstb.
glenn14 is offline   Reply With Quote
Old 01-04-2012, 10:52 AM   #6 (permalink)
Banned
Gameroom cash: $216100
View BlackG5's Photo Gallery
it was around 15 this morning when I started her up.. she hated me for it but after about 2 mins of idling it smoothed out-- 5w-30 M1 syn
BlackG5 is offline   Reply With Quote
Old 01-04-2012, 10:56 AM   #7 (permalink)
View z27ls3's Photo Gallery
I am on the accessory drive serpbelt driven items on this one,
power steering pump, water pump, idler or tensioner ? maybe?
z27ls3 is offline   Reply With Quote
Old 01-04-2012, 11:01 AM   #8 (permalink)
Banned
^my accessories are always noisy when they're cold... Not "ugly" noisy, but they sure get quieter with heat...
engine code might help here-- I'd think the V6 has more overall noise than the I4
Old 01-04-2012, 11:02 AM   #9 (permalink)
leakyseals's Avatar
Have some tire shine spray for the tires? with the car running spray the belt, see what happens. Don't over do it.
Old 01-04-2012, 11:15 AM   #10 (permalink)
leakyseals's Avatar
A trick I use to quiet pulley bearings is use the grease kit from the intermediate shaft TSB. Pull the fender flare, the small applicator tip gets in there, the grease does pretty well for a few years. For most its the alternator brushes, nothing you can do but rebuild.
Old 01-04-2012, 11:29 AM   #11 (permalink)
View INDCWBY's Photo Gallery
My 06 SE had the same issue. Had to replace the tensioner.
INDCWBY is offline   Reply With Quote
