Originally Posted by leakyseals
Looks like a DIY if its just the clear. Try buffing it out. Test on a small area. Wet sanding it out with 2000 sandpaper works also. Then buff with 3m, then polish with your fav wax. Worst case is mask at an area that is hidden, sand with 2000, over spray with clear. Thats likely what you will get charged for anyways. Last resort is paint, because of the match.
the scratches aren't that bad. Only a few areas have deep scratches, so probably paint is needed. The dent is what worries me the most, I don't know how to bump it out yet. I'll probably have to remove the rear bumper.
Originally Posted by carsrus
Try this stuff called 3m wax and adhesive remover. If something scuffed onto the paint it'll wipe right off with this stuff. Its under 10$ and it works miracles. I always use this first before going to something more aggressive.
After that use soapy water and wet sand with 2000. Light pressure is key and lots of water. after that hit it up with some rubbing compound (follow the directions on it) and then wax. You don't need power tools on a spot that small, doing it by hand wont be that bad.
http://youtu.be/XeZ4Ur-mnuk good tutorial on how to wet sand
oh, I haven't tried this.
I'll probably take my car to a few body shops and see how much it costs to get fixed. Then I'll decide whether to do it myself or let them do it.
btw, thanks a lot for your inputs
