Wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2012, 06:01 PM   #1 (permalink)
lilajto's Avatar
Gameroom cash: $100450
View lilajto's Photo Gallery
Wiring
I've been searching through the whole forum for a while and im a noob at this. I got some projects in mind that requires me to do wiring but the thing is i have no idea how to wire. I tried teaching myself how to wire but i dont know how to do it. i tried looking on youtube but it doesnt really help.
some things i dont know include:
-how do you splice wires and how do you add another positive and negative source to it?
-how do you add a wire to an existing wire so it can be longer? (example, on a piece of LED strip the positive and negative is like 6 inches long and i want to add onto it to make it longer)
-how do you give it power without directly hooking it up to the battery?
-how do you add a switch into the process so you can control when to turn it on or off?
-just basics stuff
im a super noob at it and have no idea how to do it. please help! its holding me back from doing stuff to my car and my winter break is going to be over in 2 weeks!
pictures or a video helps!
-lilajto
Lilajto's Update Thread
lilajto is offline   Reply With Quote
Old 01-10-2012, 11:56 PM   #2 (permalink)
View jchin92's Photo Gallery
if you want to extend wires you can solder additional wire on to the existing. if you don't like soldering. you can use taps like t-taps, butt connectors or posi-taps. under the steering column theres wires you can tap in to to get power, jut make sure you tap in to the one you want cuz some power is constant meaning itll stay on even when car is off. if you want a switch i believe you can just buy them at your local radio shack and wire is up with what you want.
Camry LE 2008
jchin92 is offline   Reply With Quote
Old 01-11-2012, 02:00 AM   #3 (permalink)
lilajto's Avatar
do you need a relay when i put a switch on it? also, can someone show me where the firewall is on th gen 5 and gen 6 camrys?
-lilajto
Old 01-11-2012, 08:27 AM   #4 (permalink)
View jbrnigan's Photo Gallery
You are asking very fundamental "wiring 101" questions. I suggest that you explore an automotive trades program at your local jr. college or adult ed at a local high school. At the least, have someone with a bit more undstanding of wiring "101" assist you with your projects. If you don't know where the firewall is on your car, nothing said here will be of much help - ps - the big piece of sheet metal separating the engine compartment (located under the hood) from the passenger area (where you sit to drive the car) is the firewall.
2011 SE V-6, Classic Silver, Leather, Moonroof, JBL
30% Tint, K&N, CPP Strut Brace, De-badged, Pin striped
2009 Corolla S, Classic Silver, 30% Tint, K&N,
jbrnigan is offline   Reply With Quote
Old 01-11-2012, 08:44 AM   #5 (permalink)
Gameroom cash: $245200
View fatngs's Photo Gallery
Gen5
doing electrical/wire work is pretty stait foward.... ive had noone teach me anything and ive wired up my entire sound system among alot of other things ive modded on my car
anyways ive included a pic where to go thru on the firewall on my gen5..... if u look to the left of the brake booster u will see a dinky blue wire going into the side of a rubber grommet
good luck
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 01-11-2012, 07:36 PM   #6 (permalink)
gator1939's Avatar
Gameroom cash: $244835
View gator1939's Photo Gallery
Go to
Amazon.com and search for 'basic electricity' and/or 'basic automobile electricity'. There are many books for less than $20 and if you read the synopsis you will find one or two that fit your learning needs.
gator1939
2B1ASK1
gator1939 is online now   Reply With Quote
Old 01-12-2012, 12:12 AM   #7 (permalink)
heres the hole i used on my gen 6.
Camry LE 2008
Old 01-12-2012, 12:38 AM   #8 (permalink)
lilajto's Avatar
jchin92, how do you get access to the holes?
jbrnigan, im thinking about taking a class at my local jr college.
gator1939, ill look into the books, dont wanna one thst doesnt get straight to the point
fatngs, thanks for the pic but can you take one on how to stick a wire through?
-lilajto
Old 01-12-2012, 12:51 AM   #9 (permalink)
under the hood in the way back near the air filter tube thingy haha. i used a wire coat hanger to feed small wires through. the amp power wire was easy since its thick. the wire goes through to near the gas pedal.
theres also drilling your own hole and use a grommit like i did when i had to install my alarm.
Camry LE 2008
Old 01-12-2012, 01:30 AM   #10 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I would only use a relay for anything that needs more than maybe 10A.
2007 Camry 2.4L 5M
Old 01-12-2012, 01:32 AM   #11 (permalink)
If the wires are like those for my cathode lights, then the wiring is very small, maybe 24AWG or smaller which means crimps and t-taps are really out of the question because the wire is too small.
2007 Camry 2.4L 5M
Old 01-12-2012, 02:21 AM   #12 (permalink)
true, yeah those wont work you can either solder or i believe positaps make one for 18-24 awg
Camry LE 2008
Old 01-12-2012, 08:06 PM   #13 (permalink)
You mean the Scotchlock things from 3M that have a colored circle in the middle and icky pic inside? That might work since phone wire is around 24AWG.
2007 Camry 2.4L 5M
Old 01-12-2012, 09:08 PM   #14 (permalink)
http://www.posi-lock.com/posiplug.html
thats the site its easy crimping reusable cause all it is is just screwing on and its secure too. its good depending on what your wiring.
Camry LE 2008
Old 01-12-2012, 10:41 PM   #15 (permalink)
lilajto's Avatar
i was thinking about using a non isolated connector and then putting a heat shrink tube over it. i saw a video on youtube and it looks like its pretty tight and will definitely get the job done
-lilajto
