Removing check engine bulb? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2012, 08:00 PM   #1 (permalink)
View swaptrex's Photo Gallery
Gen5 Removing check engine bulb?
I have a 02 Camry LE with a CEL issue, which I believe is the gas cap but i'm not 100%. Don't want to replace the cap right now to find out it doesn't help, but sick of looking at the CEL. I've had the cluster out, it's very easy, but the CEL is an LED so how do I remove it?
Thanks in advance.
swaptrex is offline   Reply With Quote
Old 01-10-2012, 08:51 PM   #2 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
why on earth would you want to remove it? that's the stupidest thing i've ever heard, no offense.
just put a piece of electrical tape over it if you're sick of looking at it. or better yet... get the code scanned (free at autozone) and fix it properly, which is more than likely less work than removing the cluster and desoldering the LED.
i'm amazed at some people's approach to fixing problems on the car
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 01-10-2012, 09:09 PM   #3 (permalink)
Gameroom cash: $245200
View fatngs's Photo Gallery
Gen5
i scan check engine lights all the time at my job (advance)...... it takes 10 seconds to do and youll kno what ur dealing with...... if it is a gas cap there literally like 10 bucks or it could be something else like a vacuum leak or bad cat but its better to know than to guess
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 01-10-2012, 09:13 PM   #4 (permalink)
View TurboRolla1's Photo Gallery
He's gonna need that CEL to work to get thru emissions. Don't all states have emission programs?
TurboRolla1 is offline   Reply With Quote
Old 01-10-2012, 10:36 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
heres an idea...scan the code, and fix the damn car the right way and the light will turn off.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 01-11-2012, 08:07 AM   #6 (permalink)
Thanks for the constructive tips everyone. oh wait, there were none haha. I knew I would receive comments like this, but didn't think everyone would join in... Usually the tone is set by the first reply I guess.
I've reset it numerous times, it keeps coming back obviously. I am fully aware that autozone / advance will reset it, but same problem. And no, we do not have emission tests here.
Guess i'll keep searching. Thanks anyway.
Old 01-11-2012, 08:47 AM   #7 (permalink)
knightslugger's Avatar
View knightslugger's Photo Gallery
A gas cap is $25.
if you really want to shoot yourself in the foot, de-solder the LED from the board.
I'm not going to attempt to fix stupid. I'll let natural selection do it for me.
2009 Red Camry XLE V6
knightslugger is offline   Reply With Quote
Old 01-11-2012, 08:50 AM   #8 (permalink)
Don't worry guys, just bought a cap. We will see if it fixes the issue.
Old 01-11-2012, 03:56 PM   #9 (permalink)
Welcome to the forums!
didn't mean to come off harsh, but honestly... removing the check engine light LED will cause more and potentially severe problems down the road. It's better to scan the code, look up the code to see what is causing it, and fix it properly.
Resetting the code does nothing, if the underlying problem causing the code is not fixed. It will obviously keep popping back up.
You say you have scanned the code, why don't you post what it is? We can then tell you for sure what will fix the code... and you won't be bothered by the CEL anymore.
2005 Camry "LE"
Old 01-11-2012, 05:34 PM   #10 (permalink)
No problem. I've scanned the code, it's an evap code (have the # written down). This is what lead me to think that it was a cap leak, just wasn't 100% that was it.
Old 01-11-2012, 06:13 PM   #11 (permalink)
Could it be
code P0441 EVAP incorrect purge flow ?
Old 01-12-2012, 09:50 AM   #12 (permalink)
Originally Posted by TurboRolla1 View Post
believe it was.
Old 01-12-2012, 12:35 PM   #13 (permalink)
Banned
Gameroom cash: $216100
View BlackG5's Photo Gallery
Thanks in advance.
BlackG5 is offline   Reply With Quote
Old 01-12-2012, 12:49 PM   #14 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $610031
View Zembonez's Photo Gallery
It keeps coming back because you didn't fix the problem. Fix it and it will go away.
Zembonez is offline   Reply With Quote
