P0171 help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2012, 12:19 PM   #1 (permalink)
View Arash's Photo Gallery
P0171 help!
Mass air flow sensor is acting up. I dont know why.
I have a takeada short ram intake with it extended to under the battery.
I have cleaned my original sensor with MAF cleaner and it did nothing.
Then I bought a new sensor (DENSO) original and it still throws me the error code. I Have a scanguageII So i reset it everytime. Yes I unplugged the battery everytime I touched the sensor. (touched = removing or cleaning). I am at witts end. HELP!
Arash is offline   Reply With Quote
Old 01-11-2012, 12:47 PM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
That's most likely a vacuum leak. If extra air gets into the engine after the MAF that the ecu doesnt know about the engine will run lean. If it was a MAF then it would most likely be accompanied with p0101
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
The Following User Says Thank You to BlackCamSe For This Useful Post:
Arash (01-11-2012)
Old 01-11-2012, 12:49 PM   #3 (permalink)
So i should check all my vacuum hoses connected to the air intake?
Old 01-12-2012, 05:18 PM   #4 (permalink)
turns out the two hose clamps before the sensor had become REAL loose. tightened them up and cleaned everything one more time and the problem seems to have gone away!
Old 01-12-2012, 09:25 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Good. Glad I could help man.
Arash (01-12-2012)
Old 01-12-2012, 09:57 PM   #6 (permalink)
im very thankful for your assistance. Thanks!!!
Old 01-16-2012, 05:36 PM   #7 (permalink)
I need your help again, I get the code P0101 this time.. Im going out to get a PCV valve and replace the one I have.. Any ideas?
EDIT: Just found out where the valve is.. NVM Not being replaced. What could it be?
Old 01-17-2012, 07:44 PM   #8 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
p0101 is Mass Air Flow (MAF) Circuit Range/Performance Problem. Is that the only code? And are u absoutely positive that there are no vacuum leaks downstream of the sensor? I'd clean it up with MAF cleaner and reset the code and see what happens.
