HELP With Keyless Remote Programming
Hi Everyone,
I have a Toyota Camry Altise 2004 model. I have a one button remote that was damaged so I purchased a new one from Toyota. I have been unable to program to run with the car. I go through the process of:
1. Start with
a. No key in ignition
b. Driver's door unlocked
c. All other doors locked
d. Driver's door open
2. Insert key into ignition and remove
3. Press lock, pause, unlock (2 second total cycle) 5 times
4. Close, then open driver's door
5. Repeat lock, pause, unlock cycle 5 additional times
6. Insert key into ignition and turn from lock to "on" two
times (pause in
each location 1 second). (note: "ON" not accessory position)
7. Remove key from ignition
Locks should cycle twice. If not, start over.
8. Press lock and unlock buttons on transmitter
simultaneously for 1-2
seconds then release
When I get to step 8 in the process the hazard lights start switching on and off. Can someone point me in the right direction of what I'm doing wrong.
Thank You for your help in advance.
