So I just got a brand new paid of DB691's, and have been playing around with them a little. I noticed that I was hearing a little bit of static (though it was just bad quality music) and a LOT of rattle (which honestly wasn't a surprise since I got a lot when I had my subs). So I took the back deck off and tried to pinpoint the rattle. I then unscrewed the speaker and I hear a LOT of what sounds like rattle coming from the speaker itself. I've dealt with some stuff like this before and I thought I understood it well enough. Guess I was wrong
. Following is the tech stuff.
DB691 specs are the following
Overall Frequency Response 35Hz-22kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 125 w
Power Handling (peak) 300 w
Efficiency 93 dB
Which I paired with a Rockford Fosgate P200-2
With the specs at:
100W x 2 @ 2-Ohms RMS power rating (the factory test says they're rated at 130Wx2)
I then wired them in series as shown here:
http://www.carstereo.com/help/Articles.cfm?id=35
I also used the calculator at the bottom of that page to do the following calculation
4ohm/ 2 speakers = 2ohm resistance wired in series (?)
FINALLY (And the part that most likely screwed it up)
I bridged the connection so that the + from the speaker is in the positive for one of the channels, and the - for the speakers is in the negative for one of the channels. (I followed the diagram on the amp)
I figured this would give me 260watts @ 2ohms resistance total (split 130 per speaker).
Either way the right speaker (sitting in the drivers seat) sounds awful. What did I do wrong?
