So if I understand this right, you want to get a spare key made so you won't lock yourself out of the car?
If that's your fear, then let me elaborate a little more on knightslugger's response.
The smart key system can detect whether or not your keys are outside or inside the vehicle and hence will not allow you to lock the doors if it detects the keys are inside. If you attempt to lock the doors and close them while the keys are still inside, it will beep at you and unlock the doors. If you lock it in your trunk, then the trunk is unlocked and you are able to open the trunk once again with the press of the trunk button.
When I bought the Lexus ES several years ago, I was curious as you are and I've tested all possible ways to lock the keys inside the car; trust me, the car won't let you.
The only way to lock your keys inside the car is to leave one key fob in the car, and lock the car with the 2nd key fob. And being that the key is INSIDE the car, the door sensors on the doors will not activate and people on the outside cannot open the doors. You would then need to open the car using the 2nd key fob.
Hope this answers your question.
2012 Lexus RX350 Luxury Pkg w/Nav + HUD, ML & PA
2010 Lexus IS250 AWD w/Nav
2007 Lexus ES350 Ultra Luxury w/Nav, ML & PA
2007 Camry XLE V6
2005 Camry XLE V6
