Originally Posted by JJB400
Hi All,
New to this forum. I have an 2004 Camry XLE which just had the coolant flushed. Now I only have heat on the driver side. It blows cold air in the rest of the car. Temperature runs normal. Antifreeze is full. I can get more heat if I recirculate from the inside rather than bring in air from outside. Help! It is zero in NY. Car never heats up on HOT!
Look under the dash and see if one of the damper door links has slipped off. If it has, it should be hanging and just reattach it. I remember this from a post a long wile back. Good luck...
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
