Denso or NGK Plugs for '04 Camry 4cyl? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2012, 05:34 PM   #1 (permalink)
View i_am_jim's Photo Gallery
Which is better for an '04 Camry 4cyl, Denso or NGK plugs?
Two Camrys. '94 6cyl & '04 4cyl
i_am_jim is offline   Reply With Quote
Old 01-15-2012, 06:03 PM   #2 (permalink)
Gameroom cash: $254267
View sarsman45's Photo Gallery
Both are good, just use those iridium tips so your next change will be far far away in the future. Go dual ground if you wanna pay extra, but from what I hear there is little difference between single vs dual for this engine. ( I had extra duals from another car (Avalon) and they matched the spark gap and fit perfectly)
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
Old 01-15-2012, 06:34 PM   #3 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
As sarsman said, both brand are prefect for Toyota. Thou some say that Denso holds up a bit better.
BTW, is your Camry a 4 or 6 cylinder because the title and post say different things I know the 04' 4cly (2AZ-FE) requires iridium plugs which is tougher than platinum.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 01-15-2012, 06:34 PM   #4 (permalink)
Gameroom cash: $245200
View fatngs's Photo Gallery
Gen5
Originally Posted by sarsman45 View Post
Both are good, just use those platinum tips so your next change will be far far away in the future. Go dual ground if you wanna pay extra, but from what I hear there is little difference between single vs dual for this engine. ( I had extra duals from another car (Avalon) and they matched the spark gap and fit perfectly)
just so ya kno irridium is REQUIRED on all 2azfe and 1mzfe/3mzfe w/vvti engines
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 01-15-2012, 06:40 PM   #5 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
I like the NGKs rockauto is the place to go.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-15-2012, 06:44 PM   #6 (permalink)
My bad meant iridium. Will fixpost
Old 01-15-2012, 08:19 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The dual grounds were only used in the cars with waste spark which the 2004 4 cyl model does not have.
The OEM plugs are NGK Laser Iridium or Denso Iridium Long Life which have iridium center electrode and platinum chip on the side electrode. The NGK Iridium IX and Densor Iridium do not have platinum chips on the side electrode.
2007 Camry 2.4L 5M
