Horrible brake squeal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2012, 10:25 PM   #1 (permalink)
View OhhCamry43's Photo Gallery
So my dad has an 03 Camry and the front brakes make way too much noise. It doesn't bother him much but when we switch cars on some days, it bothers the heck out of me.
I searched around on the forums and i couldn't find my exact situation. The front brakes are not even close to being worn and rotors were changed recently as well. The mechanics clean the area to see if it helps but it doesn't. The brakes squeal A LOT especially when it is cold. Applying light to medium pressure will trigger the sound. Say i was to brake from anywhere between 10-30 miles per hour, it would make such a loud squeal. but when i'm cruising and have to break a little heavier than normal, it won't squeal. Sometimes it won't even make a noise when they are warm. Also it would make so much noise moving slowly in heavy traffic, it bothers me so much and it is quite embarrassing.
Does anyone have a clue to what it could be?
OhhCamry43 is offline   Reply With Quote
Old 01-16-2012, 06:45 AM   #2 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
there is a "glaze" on both the rotors and the pads. there is a proper way to "seat" or burn in the brake system, but not too many people do this, not even alleged mechanics.
you will have to remove the wheels. then de-glaze the rotors, and pads. but usually once glazed, the problem will persist.
the proper way to seat in or burn in new pads and rotors is to apply light stead brake pedal pressure form about 20 mph to the stop sign, from about 100 feet away. do this maybe all of 4 times. then light pedal pressure form a normal speed of about 35 mph to a stop sign of about 100 feet, at least one time..from this point on, the brakes should not squeal.
however, depending on your dad's driving habits, he may the the type of driver that has one foot on the brake pedal constantly riding the brakes where he is himself causing glazing on the pads and rotors. in this instance, let it go, as no amount of anything will correct his driving habits.
and if you have to apply more brake pedal pressure to stop as you say..??
you're speeding.
Glenn8963 is offline   Reply With Quote
The Following User Says Thank You to Glenn8963 For This Useful Post:
OhhCamry43 (01-16-2012)
Old 01-16-2012, 08:46 AM   #3 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
sounds like its not a cleaning issue, rather a greasing issue. The clips brackets, caliper pins, etc. are usually the culprits. Your car uses ceramic pads, they should not squeal on the rotor. Take it back to whoever did your brakes and have the hardware re-greased. I replace just the pads no rotor turning or replacement all the time, no squeals. Make sure they used oe ceramic pads, not the cheaper metallic or semi-metallic pads.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
The Following User Says Thank You to leakyseals For This Useful Post:
Old 01-16-2012, 12:35 PM   #4 (permalink)
you're speeding.
The mechanic also commented on his driving habits. he drives very smoothly so people won't feel a huge jerk. Also meaning that he brakes very lightly and very early if he sees a need to stop. It doesn't squeal when i'm braking from higher speeds but once it reaches to a lower speed with the same light to medium pressure, it will start squealing. And yes i'm speeding or trying to stop for a red light because yellow lights in New York are very very very short, Thank you very much i'll have them checked out for this.
Old 01-16-2012, 07:42 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
It may be the brake pad material. What brand was used?
I'd go with Akebono ProAct ceramic and lube the caliper contact points with Permatex Ceramic Extreme grease.
See also:
Permanent solution for wavy/vibrating rotors?
Left rear brake caliper getting moved out of alignment.
Old 01-16-2012, 08:05 PM   #6 (permalink)
See also:
OEM toyota brake pads were used on the camry. Where can i buy those?
Old 01-16-2012, 08:36 PM   #7 (permalink)
Akebono ProAct check the catalog for the proper part number then search on Amazon or rockauto.com. Tirerack.com also has them but their prices are usually higher.
Click on Web Catalog:
http://www.akebonobrakes.com/aftermarket/index.html
If you check the pads you should see some letterings and numbers on the back. Akebono ones will have something like "AK xxx-xxx FF", NBK will have "NBK xxx-xxx FF", and I don't know what Sumitomo has. Toyota can give you pads from the lowest bidder of the batch.
So you can look for "AK" pads at the dealer or if you want Akebono ones for sure, get them on Amazon or rockauto.
Tags
brake squeal
