2003 Camry 4cyl timing chain issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2012, 12:29 AM   #1 (permalink)
View prady's Photo Gallery
Guys my car has 219k miles and has been very loud and when i turn it on the rpm meter goes to 3 and gradually car quiets down and needle comes down to 1. While i drive the steering wheel vibrates too. I took it to the mechanic i was told that timing chain needs replacement as its about time. I was under the impression that timing chains do not need replacement.
The steering wheel vibrates (shakes) it makes light clicking sounds too. I have not been able to diagnose the problem by myself. I think these two things may not be related but engine is really loud. Does timing chain needs replacement? and if it does what else along with it should be replaced?
prady is offline   Reply With Quote
Old 01-16-2012, 10:39 AM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
Best thing you can do is post a video. But it sounds like the classic dirty vvt-i/dirty engine to me. Startup ticks. Suggest you try a cleaning run before spending money. I can make suggestions if you want. Can a timing chain go? sure anything can go but I don't think that's whats wrong. if anything its a clogged tensioner. as far as the steering that's a fairly common issue you need the Intermediate Shaft greased or replaced. or an alignment and balancing.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-16-2012, 11:06 AM   #3 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Chain drives last a very long time when properly lubricated but there are many,many wear points in a chain and the wear in each link finally adds up to slop and noise. Regards
Donald E. George is online now   Reply With Quote
Old 01-16-2012, 01:30 PM   #4 (permalink)
damn some of these things i didnt even understand lol.. Dirty engine.. what exactly would that mean?
Also with "intermediate shaft" u don't mean axle shaft. Do you?
Sorry for noob qns. but thanks a lot.
Old 01-16-2012, 01:52 PM   #5 (permalink)
leakyseals's Avatar
Its ok. Its like this...mechanics fix things when they break....its not in a mechanics financial interest to help you prevent fixes....
I suspect you need an oil change. will quiet the engine down. The intermediate shaft is a part in the steering column. Inside the car. If your steering wheel makes a squeak when you turn thats a symptom. Not a big deal to replace or grease. There are many posts about it. Note the link is Avalon, but its the same shaft for the Camry, same problem.
