Tranny fluid change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2012, 06:00 PM   #1 (permalink)
View 7luvr's Photo Gallery
Tranny fluid change
Hi Guys
Got a 2002 LE 4cyl, going to change the trans fluid. I've read you can get all the old fluid out by removing the return line after draining the pan. My question is this, why not just leave the drain open and run the car? Wouldn't the old fluid from the torque converter be pumped into the pan, then out the drain? Probably stupid question, this would be way too easy.
Also, any aftermarket fluid suggestions, or stick with toyota type F (on dipstick). Thanks!
7luvr is offline   Reply With Quote
Old 01-17-2012, 06:10 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
Been changing T-IV from the drain plug, trouble free doing that. Easier than changing the oil. The T-IV is good stuff, stay with it. Get a free washer from the dealer while your there.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-17-2012, 06:14 PM   #3 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Originally Posted by 7luvr View Post
Hi Guys
Why not do the same with an oil change then?.....If you want to damage your car, maybe. There's a reason why people don't do it that way
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 01-17-2012, 06:36 PM   #4 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
Hi Guys
because it would run out fluid very quickly and ruin your transmission... even if you tried to fill it while it was running, it would not do you any good as the transmission fluid fill point is the dipstick, which runs directly to the pan. you would just needlessly waste and dirty clean fluid and you would still ruin your transmission.
The proper way to completely replace the transmission fluid is to use a flush machine... but you can DIY this at home by removing the return line as you suggested. Attach a hose to extend the line to a catch bucket, and run the car. As you are running the car, fill the transmission fluid from the dipstick. You will have to periodically stop the car to allow the filling to catch up with the draining, as it drains much faster than you can fill. Plenty of DIY threads that go into more detail so search around.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 01-17-2012, 06:40 PM   #5 (permalink)
leakyseals's Avatar
Edit: The car was NOT running.
Old 01-17-2012, 06:59 PM   #6 (permalink)
Great points..all. Will do the flush procedure or take it someplace I can trust to do the job right.
Old 01-17-2012, 07:02 PM   #7 (permalink)
leakyseals's Avatar
Right, we don't get all the oil in an oil change either, up to 1/2qt of old goo gets left behind.
Old 01-17-2012, 07:06 PM   #8 (permalink)
leakyseals's Avatar
Its over $100 for a flush every 30-40k. If that doesn't happen, all the fluids junk. A $26 drain and fill every other year is a whole lot cheaper, most of the fluids almost new or half way gone all the time. Something to think about.
Old 01-17-2012, 07:20 PM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Or you can just do 3 drains/refills with a short drive in between. The down side taking it for a fluid exchange is that it may not be done or the wrong fluid gets used.
Doing the cooler line flush the engine has to run, because it runs the ATF pump. Otherwise you'll just drain new fluid out of the drain hole. And as others mentioned, if you run the engine without plugging up the drain, then the ATF pump will run dry and can cost you a transmission.
Besides the dino Toyota T-IV (Mobil-3309, but there is no price advantage), Valvoline MaxLife ATF too. Not to mention boutique ATFs. If you buy enough then Advance Auto's ~40% coupon code would be a great deal.
See also:
The Following User Says Thank You to JohnGD For This Useful Post:
leakyseals (01-17-2012)
Old 01-17-2012, 07:38 PM   #10 (permalink)
leakyseals's Avatar
Originally Posted by JohnGD View Post
Wow. Suppose I should tell my ex wife about this...nah maybe not ha!
