Next: Coolant change? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2012, 08:23 AM   #1 (permalink)
View 7luvr's Photo Gallery
Thanks again for answering the tranny fluid question. Since I'm going to be working on the car anyway, how often should I change coolant? It's been done twice, 120K+ miles, still looks good. I put the green stuff in last time, should I stick with Toyota fluid there too?
This car has caused me ZERO troubles, and we bought it new. Hoping to keep in that way till the wheels fall off.
Thanks!
7luvr is offline   Reply With Quote
Old 01-18-2012, 09:49 AM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
Thanks!
The Toyota red and pink fluids were designed for Toyota engines - to prevent corrosion on the Toyota aluminum block, head, and radiator. Using green in a Toyota is NOT recommended. But your already doing it, so stay with it. You should not be mixing coolants. Its one or the other. If its all green stay with green.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-20-2012, 05:27 PM   #3 (permalink)
Will do. Should have researched better. Thanks!
Old 01-20-2012, 09:51 PM   #4 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Next time the coolant is done you should switch to pink coolant. Your interval-about every 60k-is fine.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 01-21-2012, 06:39 AM   #5 (permalink)
Stella
Gameroom cash: $135500
View SoUtHsIde_ChI's Photo Gallery
^ +1 or since it is winter you can have it checked to see the freezing point of the fluid. that is sometimes a good indication whether or not the fluid needs to be changes.
You can buy a testing kit that is reusable to test your coolant
2011 Camry SE_
SoUtHsIde_ChI is offline   Reply With Quote
Old 01-21-2012, 08:37 AM   #6 (permalink)
yeah, I'll put in red next time. If I do a GOOD flush with distilled water it should be ok.
