Transmission Issue? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2012, 07:32 PM   #1 (permalink)
View dg1653's Photo Gallery
Transmission Issue?
I have a 2005 Camry, Base, 4cyl, 190k. The last couple of weeks while everyday driving the engine will rev up like the transmission has gone to neutral. It only does it for a couple of seconds and then back to normal. There is no rhyme or reason why it does it. We bought the car brand new and the fluid has never been changed. Have any of you ran into this problem? Thanks.
dg1653 is offline   Reply With Quote
Old 01-18-2012, 07:42 PM   #2 (permalink)
Gameroom cash: $154045
View Zmon's Photo Gallery
You bought it brand new, has 190k miles and the transmission fluid has not been changed not even once? It's probably time to change it.
Zmon is online now   Reply With Quote
Old 01-18-2012, 07:43 PM   #3 (permalink)
Gameroom cash: $814801
View zythr's Photo Gallery
Does it appear to be slipping?
zythr is offline   Reply With Quote
Old 01-18-2012, 07:50 PM   #4 (permalink)
I knew i was gonna catch heck for that.. It is definetly time.
2005 Camry, 4cyl, Auto, Base
Old 01-18-2012, 07:52 PM   #5 (permalink)
Not slipping...almost like disengaging or going to neutral. The problem only happens sporadically.
Old 01-18-2012, 07:57 PM   #6 (permalink)
Gameroom cash: $254267
View sarsman45's Photo Gallery
Does it happen when you are driving or at a stop? Is your AC on? The condenser turning on/off can make it seem like the engine is revving high. It also depends on how much refrigerant is in the system. Too much makes the engine rpm skyrocket
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
Old 01-18-2012, 08:02 PM   #7 (permalink)
Originally Posted by sarsman45 View Post
Does it happen when you are driving? Is your AC on? The condenser turning on/off can make it seem like the engine is revving high. It also depends on how much refrigerant is in the system. Too much makes the engine rpm skyrocket
It has done it with the AC on and off. Also its while driving down the road mostley at around 60 mph. And this is definitley something that is out of the ordinary.
Old 01-18-2012, 08:04 PM   #8 (permalink)
Have you checked the transmission oil? If its black and smells burnt, time for some new oil. Drain and refill, dont flush. See if it gets better. There are methods that let you do a full drain/refill by running the car and refilling while draining from a hose, but i haven't the slightest in how it goes. Its here somewhere, just needs a lil digging. If you do a normal drain/refill, it will take maybe 3-4 of them to clean out most of the old tranny oil. Best time to do them is when you do oil changes since you're under the car already
Old 01-18-2012, 08:12 PM   #9 (permalink)
also, does it happen on shifting?
Old 01-18-2012, 08:16 PM   #10 (permalink)
It doesn't happen while shifting. What the best fluid to put back in it? How many quarts does it usually take to drain and refill?
Old 01-18-2012, 08:24 PM   #11 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
First check the condition and level of the ATF, then change it along with the felt filter that's probably plugging up.
Old 01-18-2012, 08:27 PM   #12 (permalink)
Is the felt filter under the pan?
Old 01-18-2012, 08:42 PM   #13 (permalink)
It's in the pan. There are a few pan bolts that are hard to access. Some TN'ers don't have problems but others have to jack up the transmission slightly. So YMMV.
Here is a picture for the U250E transmission (do you have the 5-speed? Check the door decal for the exact code). It's $20 at many parts stores:
http://info.rockauto.com/WIX/DetailW...asp?Part=58618
You can also use fully synthetic Valvoline MaxLife ATF from Advance Auto. With their ~40% coupon code it's a real deal.
Old 01-18-2012, 09:02 PM   #14 (permalink)
leakyseals's Avatar
Gameroom cash: $165300
View leakyseals's Photo Gallery
I had that problem on my 02, a simple drain and fill with T-IV was all it needed. If your stick says T-IV on it, suggest you stay with it. get a new washer from the dealer while your there, they give them away for Free.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-19-2012, 12:49 AM   #15 (permalink)
I... never got washers for free before
