Check your batteries!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2012, 10:14 PM   #1 (permalink)
View cipsaz's Photo Gallery
This is a second time that I got burned with a dead battery. Yes, the first time, a 5 years ago died on me instantly at the store, so my dad came with a new battery.
So yesterday, at the airport where you cannot stay any longer than a few minutes, the battery died instantly on a start up. What a frustrating day and the place to get stuck... It took two hours to find a driver with a jump cables. The security was about to call to a tow service. Glad I got lucky once again.
If you have an old battery and it does work like a charm - don't trust it. Go to AutoZone or some other place for a free check up.
cipsaz is offline   Reply With Quote
Old 01-19-2012, 10:48 PM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Always good advice.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 01-19-2012, 10:52 PM   #3 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $610031
View Zembonez's Photo Gallery
Batteries don't just go from good to flat in an instant. They tend to give signs of weakening prior to failing completely. I'd bet you have some sort of cable or connection issue, provided your charging system is charging.
Zembonez is offline   Reply With Quote
Old 01-19-2012, 10:54 PM   #4 (permalink)
Need For Speed
Not always. Not often, but sometimes, a battery will just 'flatline', so to speak. I've seen it only a couple times before.
Old 01-19-2012, 11:14 PM   #5 (permalink)
^__^
alexorozco92's Avatar
Gameroom cash: $266000
View alexorozco92's Photo Gallery
My battery was leaking for like 2 days, didn't know at the time though.
A foul odor just kept seeping into my cabin and I didn't know what.
One day when I got out work I turned on my car and the smell was unbearable, and then my car shut off.
Popped my hood to an oozing battery. :/
Low'N Slow Crew
08 G37: Ksport Coilovers, Varrstoen ES 2.2.2 19x9.5/10.5 +12, SPC Camber Kit
08 Camry: http://www.toyotanation.com/forum/showthread.php?t=386218
alexorozco92 is offline   Reply With Quote
Old 01-20-2012, 06:32 AM   #6 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
Another good advice, have your OWN jumper cables. Especially if you know you would have the problem.
CarDomain
Old 01-20-2012, 10:49 PM   #7 (permalink)
270hp = Happy Foot
Gameroom cash: $395545
View aznlunatic206's Photo Gallery
Optima yellow top FTW!
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 01-21-2012, 12:55 AM   #8 (permalink)
ilikecamrys
Cking's Avatar
Gameroom cash: $532185
iTrader Score: 17 reviews
View Cking's Photo Gallery
Yeah man be careful, always check your battery. I'm surprised we don't have some kind of "check battery" symbol. Or at least I never heard of it lighting up. I think batteries are supposed to last 3-5 years anyway.
My OEM lasted 3years only...
I had sulfur build up on one of my terminals, and startup took 2-3 seconds, it was so weak. Even after cleaning it off with baking soda was no help. When I took it out, it leaked acid all over (for some reason I thought it was condensation build up under the battery) and didn't notice until it started to burn my skin
Anyway, always be careful when handling batteries!
Was thinking about buying that one until upon further research found that there was one called:
Interstate Megatron
Haha had to get it cause it was called Megatron
2k8 V6 Camry SE\\55w6000kHID||3000kfogs||Work Emotion CR-ULTIMATES
||BuddyClub Coilovers||SPC Camber Bolts||TRD Dual Catback Exhaust
||Megan FrontTowerStrutBar||StopTech Slotted Rotors||PosiQuiet Pads
||Fujita ColdAirIntake||My thread!||TN lanyards!||
Cking is online now   Reply With Quote
Old 01-21-2012, 02:00 AM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Johnson Controls Inc makes (some/all?) for Interstate. And Optima is a JCI battery. So are the Autozone ones - great value and warranty. 7 or 8 year prorated depending on Duralast or Duralast-Gold.
Yeah, battery warning is common on European cars. They measure current draw and voltage drop at start up and give you a warning if needed. But I guess if the battery dies before this test then SOL.
Old 01-21-2012, 05:24 AM   #10 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Costco batteries are from Johnson Controls also and go for about $60 which makes them very competitive (assuming one already has Costco membership). The warranty is 36/100.
2007 Camry 2.4L 5M
Old 01-21-2012, 05:28 AM   #11 (permalink)
Daybreak-Coffee-Cruising
XtraRevsSurely's Avatar
View XtraRevsSurely's Photo Gallery
Battery cables are must in the trunk for me. Even if you don't need them much for yourself-you can always help someone else! It'll somehow come back to you!
XtraRevsSurely is offline   Reply With Quote
Old 01-22-2012, 08:02 AM   #12 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
I have numerous battery war stories accumulated over the decades. I've had batteries blow cells on brand new cars. Had a 67 Ford Falcooon whose battery remained good for the 8 years of ownership. Had a 74 VW bus whose battery failed 5 weeks after I took delivery. 8 volts--dead. Here's my time consuming trick. I open the hood after the car has sat all night and check the voltage at the battery--say 12.7 volts. I jot that down on a sheet of paper that lives in the glove box. I date it. Months out I do it again. And again. When I notice the standing voltage begin to drop off I go shopping.
When was the last time that your battery failed at a convenient time? I change it out when it is convenient to do so, not when I must on a cold rainy or snowy day or at 3 pm in August. Cheap insurance.
gdanaher is offline   Reply With Quote
Old 01-23-2012, 09:36 AM   #13 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
Whatever you do - DO NOT buy a battery from Advanced Auto. The warranty is a scam (they NEVER pay out) and you will just waste your time and money with them. I had to go through it twice with two different cars before I realized that they must read a script when telling a customer to F - off.
Walmart, Costco, etc have a much much better policy in dealing with battery warranty.
I have a local shop that sells Interstate that also has a great policy on warranty claims.
I have had factory original batteries go almost 10 years (my current Camry just passed 7 years on the original battery and still going strong, even with 14F temps).
I never had an Advance Auto battery go more than 2 years without having issues. You take it in for a warranty claim, they put it on their 'charger' and zap it with 5 million amps, then tell you it's fine and your car must be the problem.
kenny1773 is offline   Reply With Quote
Old 01-23-2012, 11:59 PM   #14 (permalink)
Interstate Megatron
The Megatron battery is not a good one. Those in the know get the Megatron Plus because it is better by far.
2007 Camry 2.4L 5M
Old 01-24-2012, 12:26 AM   #15 (permalink)
ilikecamrys
Cking's Avatar
Oh for those in know.... you mean this one?
Is that what youre running too?
Had to get it just for the name lolol too bad they didn't have an "optimus" battery.
Anyway, did the OP figure out the problem?
