Good job with the fluids, very important. Changing the oil at 2k is unnecessary unless your cleaning the engine. For the cost your paying to change so often you would be better off with a premium synthetic and a good filter every 6-7k. Why its not shifting correctly would be not changing the fluid till it was too late and ther transmission burned up, not properly setting level ( running hot line) and using the wrong fluid (A universal fluid when it says T-IV, etc) Why it stalls going into gear on a cold day would likely be a dirty throttle body, dirty fuel system. Cleaning the throttle body on these cars is not hard so long as you remember there is no cable, its electronic so care must be taken opening the plates. PM me for an explanation if you want its not a big deal. There is a small hole in the TB that needs to be cleaned, you will see it. Also clean the MAF sensor with MAF sensor cleaner. I use the MAF cleaner for the TB as well, works really good for that. Put in a new air filter. Take it from there.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
