+1
It's not hard to find out what code(s) are causing the lights. take it to advance auto so they can pull the codes with a code reader. you can then take those codes, post them here, and with any luck you should be able to find out what the solution is. could be as simple as a gas cap...
better yet, go to a Toyota Dealer and just get it over with.
Resetting the lights will not fix the problem. they will re-illuminate when the code is triggered again, and they will trigger again.
2009 Red Camry XLE V6
