how do I get wires thru the trunk and into the back seat on an 07 XLE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2012, 03:19 PM   #1 (permalink)
Gameroom cash: $163285
View HotRod53's Photo Gallery
I mounted my XM antenna and got in around the window rubber into the trunk. I then pulled the side panel and went in thru what I think is what the dealer told me a pass thru hole. There is a triangle shaped hole that lines up with the center of the rear headrest, I rolled up my wires and put them thru.
I can't feel the wires when I shove my hand thru the crack in the upper/lower rear seat, so I assume that I need to pull the rear seat bottom. I did a search and saw to push in and pull up on the seat base, so far no good. The outer corner of the seat is pretty loose, but nothinmg gives me access to the wires that I shoved thru.
Any advice?
HotRod
'06 Tacoma DC, Super White, Leer 100R, bed mat, K&N, Weathertech liners and vent visors, TSB 4 pack springs, Ride Rite air bags, TSB Cat converter, TSB exhaust manifolds, driving light mod, repaired my compass (3 times), 162K+. '06 Camry XLE, V6, '07 Camry XLE I4.
HotRod53 is offline   Reply With Quote
Old 01-22-2012, 06:44 PM   #2 (permalink)
Just found this, sounds like more than push back and pull up, I didn't see any bolts:
Remove the mounting bolt from the rear seat cushion with a socket wrench. You will have to lift up the front edge of the cushion to get at this bolt. Then, pull the cushion up and out of the Camry.
Read more: How to Remove a Backseat Out of a Camry | eHow.com http://www.ehow.com/how_7530983_remo...#ixzz1kEnG46OA
HotRod
Old 01-22-2012, 07:07 PM   #3 (permalink)
Found this, sounds like I just firmly YANK it up:
http://ww2.justanswer.com/uploads/mo...85450_seat.pdf
HotRod
