Originally Posted by punkgen6driver
Hi, I am new to the forum, and new to the camry, but not new to car forums, and I know all about searcing questions asked thousands of times before...BUT, I am looking for some quick answers to specific questions and there are a TON of pages to search through here.
These questions are all based on the fact that I am picking up an 09 Camry SE with the V6 and just over 40k miles this Friday. I know the SE has upgraded suspension parts so these questions I have lingering.
1. What is the diameter of the STOCK SE rear sway bar?
2. Are there major differences between the 19mm and 23mm UR rear sway bar?
2.a. Which would be more of a beneficial upgrade on an SE?
2.b. I heard of install "issues" with the 23mm bar...can anyone chime in?
2.c. Does UR provide new bushings with their bars?
3. Which KYB struts are the same as the OEM SE struts?
4. I am debating installing TRD springs on the car (which again has just over 40k miles)...should I change the struts at this time as well?
4.a. Which struts should I go with?
5. Is the UR front strut bar a worthy upgrade over the STOCK SE bar?
Thanks for your help in advance! I am trying to get all of the information I am seeking at once.
Looks like you didn't do the most simple search
1.
Posted by one of the Moderators here on Toyotanation.
2. There's about 15% more stiffness from the 23mm vs the 19mm.
I heard people here say they can feel a difference, but it could all be in their mind.
2a. 23mm obviously, but it depends on how much you want to spend.
2b. Requires more elbow grease I remember reading.
2c. N/A, but you can go to Toyota dealer to get some.
3. KYB GR2.
However, Toyota's factory tunes the GR2 they put into SE's to be a 15% more softer.
If you went to buy a new set of GR2s from a shop, it'd be stiffer than the factory SE,
even though both are essentially the same.
^Although I read that from a member who just replaced his struts, I doubt the difference is worth much.
4. Do not get TRD/Eibach. The drop is uneven. The gap between the tire and fender is 4 fingers (front) and 2.5 (back), so your car will look higher in the front and lower in the back.
You can find suspension options
here
4a. KYB GR2s.
Ever consider coilovers? If you're looking for adjustable lowering/stiffness , I'd say that's your best best.
Lowering springs + bars < coilovers. Instead of spending $600+, coilovers are only $800~ and you can keep your stock suspension and put them back on if needed.
5. The SE does not come with a FRONT strut bar. It only has the REAR sway bar.
These questions have been answered (or information has been provided) before but since it's your first time and you might not know what keywords to enter in the vast search premises, I'll just help you out with that.
Good luck with modding and if you have any questions, feel free to PM me or post on this thread.
Happy to help newcomers
Keep us posted on your progress!
