Originally Posted by BlackCamSe
i had a +25 offset in the rear of my car. Had to role fenders and -4 camber
Can you tell me how you got -4 camber? Not doubting you but stock goes to -2 only so just wondering where I can get the modifications to camber my rear past -2. Plus I dont know any coilovers with camber plates that go to -4 as well
Originally Posted by BlackG5
that's excessive.
I shaved my rears flat (Gen5, less clearance) and ran -2.5 with an 18x9.5 +25, never rubbed..
then stepped up to a 19x9.5 +25, same ride height... rubbed like a BLEEEEP
Lol maybe the 19s had less vertical travel distance into the fender thats why.
Also tire size matter too, were you runnning different tire sizes?
18s tend to be fatter too.
Originally Posted by sosmooth
I found a set of 18 in rims but the offset is 32 and I'm not sure if they'll fit properly on a 07 Cam. stock. I've read that a 35+ high offset is recommended. Does anyone have rims that have a offset lower than 35 and fit properly with no problems?
I'm really surprised no one asked you what width those rims are.
Those offsets are a little high but if you can give me the wheel width, I can be a more sure.
ex.
18x9.5 +30 offsets are higher than 18x8.5+35
the 8.5 is farther out than the 9.5.
