09 camry v6 transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2012, 11:59 PM   #1 (permalink)
nuchieboy's Avatar
Gameroom cash: $203799
View nuchieboy's Photo Gallery
Gen6 09 camry v6 transmission
hey guys well i just hit 40,000 miles and spring time is quickly approaching and i was thinking about getting my transmission fluid changed soon. I think im probably going to take it to the mechanic i always go to to get it changed. I asked him how he would change the fluid if it was a sealed tranny and he claimed they can pull it out through the cooling lines? Is this a safe way of doing this? I also saw this video....does this apply to an 09 camry v6 also? thanks in advance!
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 01-31-2012, 12:19 AM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $166700
View leakyseals's Photo Gallery
He only drained added a quart and a half ? what is the capacity?
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-31-2012, 07:01 AM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Theres a fill hole on the side of the trans. And the "drain bolt" on the trans isn't a drain bolt. There's a sleeve that goes up there which is how fluid is adjusted. Fluid is at the right level when fluid "trickles out" if you drop the pan it should take about 3 quarts. But the fill procedure is a PITA. I'll post pics of the paperwork I have from all data. As ill be doing my trans soon
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 01-31-2012, 09:59 AM   #4 (permalink)
Gameroom cash: $182500
View Paul3637's Photo Gallery
Don't change it - may cause more harm than good
Your car has lifetime synthetic "WS" - World Standard fluid that is designed to last the life of your car and is not compatable with other types of tranny fluid. Changing the fluid is a very delicate operation. If you do any damage to tranny, you could void your warranty. I would at least hold off until 60,000 miles for warranty purposes. [I have an 09V6 too on which I do flawless maintenance. In all our prior Toyota/Lexus vehicles, we changed fluid every 30,000 miles. I decided not to even think about it until 100,000 on this one.]
Direct copy and paste from TSB - TC010-07 (dated 6-28-07):
World Standard (WS) Automatic Transmission Fluid (ATF) was introduced to reduce maintenance costs and increase the mileage between scheduled maintenance checks. Here are some important tips when working with ATF-WS in Toyota vehicles requiring
its use.
100,000 Maintenance Interval — Inspection only; ATF-WS does NOT require any
flushing or changing during the life of the vehicle.
The use of Genuine Toyota ATF-WS is recommended.
The use of additives or aftermarket fluids that are considered compatible
or substitutes may result in shift concerns and damage to the internal
transmission components.
ATF-WS is NOT compatible with T-IV or Dexron ATF.
Containers storing Toyota ATF-WS should always be sealed — If exposed to the
atmosphere, ATF-WS may absorb moisture and potentially cause shift concerns if
used in operation.
One time use only.
When performing repairs on ATF-WS equipped transaxles, it is important to use
only
new, clean ATF–WS when refilling the ATM.
ATF-WS equipped ATMs may use the overflow type procedure — Any fluid
drained from the overflow plug should be discarded following proper local
regulations and never reused. Failure to do so could result in shift concerns and
damage to the internal transmission components.
Paul3637 is offline   Reply With Quote
Old 01-31-2012, 10:07 AM   #5 (permalink)
leakyseals's Avatar
One of the main reasons i drive toyotas is because they are so easy to work on and maintain. I like to/want to maintain my cars. If I cant drain the tranny it would drive me nuts knowing there is old fluid in there. I'm just not bought in on lifetime fluids yet.
Old 01-31-2012, 12:25 PM   #6 (permalink)
View william m dowd's Photo Gallery
The 2007 and newer camry is supposed to go 100k on the tranny fluid but I have been told by a few Toyota techs to change it at 50k. It takes a special set up to change the fluid the trans fluid has to be around 115 degrees and it is a drop and fill type fluid exchange.
william m dowd is offline   Reply With Quote
