Outside Thermometer Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2012, 10:33 AM   #1 (permalink)
View tony jj's Photo Gallery
I have a 2004 Solara. Ever since I could remember, the outside thermometer has been giving me false readings. When I pulled out of my garage today, the outside thermometer read 50 degrees. I drove to work without stopping for 60 miles and the gauge still read 50 degrees. When I got to work, the gauge guickly dropped to 41 degrees.
This problem has happened many time before. When the car is in motion, the themperature will not change. When the car comes to a stop, then it will adjust.
Where is the sensor for the thermometer? Maybe the air is not reaching it due to the high speed.
tony jj is online now   Reply With Quote
Old 01-31-2012, 10:50 AM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $166700
View leakyseals's Photo Gallery
I have a 02 Camry xle, noticed the same delay you mention as long as I owned it. Assumed that's normal, was yours working quickly before?
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-31-2012, 01:01 PM   #3 (permalink)
Gameroom cash: $203000
View Donald E. George's Photo Gallery
On my 04, the sensor is behind the lower grill on the driver side. Mine is fairly accurate. Regards
Donald E. George is online now   Reply With Quote
Old 01-31-2012, 08:04 PM   #4 (permalink)
Gameroom cash: $163785
View HotRod53's Photo Gallery
I have 2 Camrys and a Tacoma, all have a delay in the temp catching up. The sensor is behind the grille somewhere and probably need some airflow on initial startup. I believe that the sensor only updates occasionally to keep it from flickering around. Normally I leave home and drive into town before the temp number looks believable, if its more than a couple of miles, something is wrong.
HotRod
'06 Tacoma DC, Super White, Leer 100R, bed mat, K&N, Weathertech liners and vent visors, TSB 4 pack springs, Ride Rite air bags, TSB Cat converter, TSB exhaust manifolds, driving light mod, repaired my compass (3 times), 162K+. '06 Camry XLE, V6, '07 Camry XLE I4.
HotRod53 is offline   Reply With Quote
The Following User Says Thank You to HotRod53 For This Useful Post:
leakyseals (01-31-2012)
