2011 Camry, No Transmission Dipstick? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2012, 09:22 PM   #1 (permalink)
ydopen's Avatar
View ydopen's Photo Gallery
I looked everywhere, is this some kind of a joke? Do they want this to tear up so you will spend more money with them?
11 Camry Se 4cyl,
95 Camry v6 17in o8 camry wheels. Tint.
83 toyota pk. Longbed automatic all-original.
98 Expedition 16in rebel racing black rims.
01 Chevy Metro
ydopen is offline   Reply With Quote
Old 01-31-2012, 09:45 PM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $254450
View Tech1984's Photo Gallery
What kind of talk is this? Toyota is a pretty smart car company. Don't you think they did this for a reason? No, not to spend more money with them.
Drive your SE, with confidence.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is online now   Reply With Quote
Old 01-31-2012, 09:50 PM   #3 (permalink)
leakyseals's Avatar
Gameroom cash: $166700
View leakyseals's Photo Gallery
They get too many complaints and bad reports caused by lack of maintenance. So they self-maintain now.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 01-31-2012, 09:58 PM   #4 (permalink)
View srkovarik's Photo Gallery
I read an article about a year ago about new high-end cars removing *oil dipsticks* from my POV to "incentivize" consumers to utilize dealer service.
Demise of the dipstick.
srkovarik is offline   Reply With Quote
Old 02-01-2012, 06:29 AM   #5 (permalink)
ydopen's Avatar
How often do i change the fluid? any special tools needed? Anyone have a write up with picks for the 2011 Change? How often do you change it?
Im just one that likes to play with my cars myself and not have to take it to the dealer or a shop, so this is a concern to me.
11 Camry Se 4cyl,
01 Chevy Metro
Old 02-01-2012, 07:35 AM   #6 (permalink)
Gameroom cash: $182500
View Paul3637's Photo Gallery
This keeps coming up ... sticky needed?
This came up yesterday so I will repost TSB language about 100,000 miles before you should even think about the subject:
09 camry v6 transmission
Direct copy and paste from TSB - TC010-07 (dated 6-28-07):
World Standard (WS) Automatic Transmission Fluid (ATF) was introduced to reduce maintenance costs and increase the mileage between scheduled maintenance checks. Here are some important tips when working with ATF-WS in Toyota vehicles requiring
its use.
100,000 Maintenance Interval — Inspection only; ATF-WS does NOT require any
flushing or changing during the life of the vehicle.
The use of Genuine Toyota ATF-WS is recommended.
The use of additives or aftermarket fluids that are considered compatible
or substitutes may result in shift concerns and damage to the internal
transmission components.
ATF-WS is NOT compatible with T-IV or Dexron ATF.
Containers storing Toyota ATF-WS should always be sealed — If exposed to the
atmosphere, ATF-WS may absorb moisture and potentially cause shift concerns if
used in operation.
One time use only.
When performing repairs on ATF-WS equipped transaxles, it is important to use
only
new, clean ATF–WS when refilling the ATM.
ATF-WS equipped ATMs may use the overflow type procedure — Any fluid
drained from the overflow plug should be discarded following proper local
regulations and never reused. Failure to do so could result in shift concerns and
damage to the internal transmission components.
Paul3637 is offline   Reply With Quote
Old 02-01-2012, 03:32 PM   #7 (permalink)
Sevn86's Avatar
View Sevn86's Photo Gallery
No joke, you just dont have to worry about the trans fluid anymore. I think its great.
Sevn86 is offline   Reply With Quote
Old 02-01-2012, 03:38 PM   #8 (permalink)
I'll Beat your Porsche!
2011SECAMRY's Avatar
View 2011SECAMRY's Photo Gallery
Toyota did this not only to keep people from putting the wrong fluid in and ruining their transmissions but to also prolong intervals.
2011 Camry SE V6 Loaded
K&N Intake || Tein Suspension || 6000K HID Headlights ||
3000K HID Foglight's || 20% Tint || UR Strut Bar || UR Rear 23MM Sway Bar || StopTech Drilled Rotors || Hawk Pads ||
Owning it at the track! See Below:
http://youtu.be/1Vm6PNearEU?hd=1&t=1m30s
2011SECAMRY is offline   Reply With Quote
Old 02-02-2012, 07:05 AM   #9 (permalink)
ydopen's Avatar
Sweet so just change it every 100k, no need to check it
11 Camry Se 4cyl,
01 Chevy Metro
Old 02-02-2012, 08:04 AM   #10 (permalink)
scamry's Avatar
Gameroom cash: $194025
View scamry's Photo Gallery
it says you dont need to change it.
I miss the old days of TN.
scamry is offline   Reply With Quote
Old 02-02-2012, 11:02 PM   #11 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
it is lifetime fluid, but I have seen people still change it at 100k miles. It's not cheap, close to $200 to get it done because of the WS fluid
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 02-03-2012, 04:11 PM   #12 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If the car is a keeper maybe 20-30K miles drain/refill with a filter change (~$20 kit with gasket) every other time; otherwise hey it's lifetime fill and never needs to be changed . But getting to the ATF filter can be a pain for some people, with a few bolts under the subframe.
You can check out the discussions on BITOG (Bob is the Oil Guy forums), some suggest the fluid is worn out by 20K miles. But not everybody is comfortable using boutique ATFs (Amsoil, Redline) or other fluids like Walmart's SuperTech Mercon-V/Dexron-VI, or Valvoline MaxLife claimed suitable for WS in place of the OEM fluid.
http://www.valvoline.com/pdf/maxlife_atf.pdf
To refill it the transmission has to be level, the engine running after the initial topoff, gears shifted through and the fluid temperature at about 40 deg C in most cases.
The old way sure was a lot easier but this manual transmission style drain/refill has been used by Europeans for ages.
