Indicator lamp heat/cool selector switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2012, 06:54 PM   #1 (permalink)
View 7luvr's Photo Gallery
How hard to replace the little backlight lamp behind the heat/cool selector switch on 02 camry? I poked around and could find no easy way to get behind the dash. Appreciate any advise.
7luvr is offline   Reply With Quote
Old 02-01-2012, 09:17 PM   #2 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
its very easy...... take a flat head screwdriver or trim panel tool and stick in on a bottom corner (L or R) and pry it out then repeat on the other side..... whole assembly should come out and disconnect the 2 electrical connectors.... take the flat head to the back and rotate the burnt bulb 1/4 turn counter clockwise then it will release..... pop in the new bulb, rotate 1/4 turn clockwise, reconnect wires, take assembly and pop it back in, then have a beer or two
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
The Following User Says Thank You to fatngs For This Useful Post:
Donald E. George (02-02-2012)
