Replacing seals and water pump on 2005 V6 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2012, 09:40 PM   #1 (permalink)
View jmichaelo's Photo Gallery
Hi,
I am bringing in my V6 2005 Camry XLE in for a pulley recall and have reached 90,000 miles. The dealer told me I should also have the timing belt, water pump and engine seals replaced since they are all under the same engine side cover. I am considering the timing belt, but do I need to replace the oil seals and water pump? What is the likelihood of their failure?
Thanks,
Michael
jmichaelo is offline   Reply With Quote
Old 02-01-2012, 10:40 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
yes you should.
because even if they don't fail right now, there's a good chance that they will in another 20-30K, and then you would have to pay to change them all, and also pay for another timing belt since your old one will be wrecked by oil.
long story short, pay a bit more now for seals + water pump now, or pay even more later for everything again
HaHa
The Following User Says Thank You to Eye8Pussies For This Useful Post:
jmichaelo (02-01-2012)
Old 02-02-2012, 02:17 PM   #3 (permalink)
Gameroom cash: $203000
View Donald E. George's Photo Gallery
Change the timing belt,tensioner,idler pulleywater pump and I don't know about the seal but labor to do that fix shouldn't be over an hour. Depending on your mileage,the call is yours.Regards
Donald E. George is online now   Reply With Quote
Old 02-02-2012, 05:31 PM   #4 (permalink)
leakyseals's Avatar
Gameroom cash: $166700
View leakyseals's Photo Gallery
I suppose if your in there may as well. I've had toyotas up to 300k and never replaced water pumps thermostats or anything else but I am neurotic about changing the coolant.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 02-03-2012, 04:19 PM   #5 (permalink)
View chuckoff's Photo Gallery
300K on wate rpumps, or anything else? Really? You are one lucky person.
A correct timing belt job includes timing belt, timing belt tensioner bearings #1, and #2, cam seals, front crank seal, timing belt tensioner, water pump, and drive belt(s). If you are doing it yourself you can cheap out on any of the above mentioned parts since you will be fixing it your self when somehting fails. Most shops won't do the job with warranty unless they do everything.
chuckoff is offline   Reply With Quote
Tags
oil seals, timing belt, water pump
