Is my tranny overfilled? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2012, 06:53 PM   #1 (permalink)
View 7luvr's Photo Gallery
Just had trans flushed by dealer. The wording is worn to the point I can no longer read it, but the level is slightly above the 2nd set of notches (furthest from the tip). I think thats the 'hot' reading, correct? It's reading this way with engine cold.
7luvr is offline   Reply With Quote
Old 02-02-2012, 07:06 PM   #2 (permalink)
leakyseals's Avatar
Gameroom cash: $166700
View leakyseals's Photo Gallery
The car is running when you check, right? Slightly over the second HOT notch when vehicle idling HOT is fine, no worries. I do mine like that too, less air bubbles.
00 Corolla CE 1ZZ-FE 164k M1 HM 5w30/Kreen XG4967
02 Camry XLE 2AZ-FE 206k M1 HM 5w30/M1 0w20/Kreen/moS2 L1447
If u like what I write hit the THX button. That way I know to continue contributions or STFU.
leakyseals is offline   Reply With Quote
Old 02-02-2012, 07:15 PM   #3 (permalink)
Nope, it wasn't running when I checked..I'll do that thanks.
Old 02-02-2012, 07:24 PM   #4 (permalink)
leakyseals's Avatar
No problem. Most accurate...
Always flat surface.
Oil = engine off for an hour, cold
Tranny = engine on for a half hour, hot.
The Following User Says Thank You to leakyseals For This Useful Post:
Donald E. George (02-03-2012)
