HID 5000K Bulb into 4300K Ballast - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2012, 10:09 PM   #1 (permalink)
View phitat's Photo Gallery
I installed a Xtreme 4300k HID kit about a month ago and it's working great. I just wanna see if the 5000k bulb is compatible with my 4300k ballast? If it is then I'll go ahead and get some. I also wanna know if I'll lose any light output if I change to the 5000k bulb? Thanks in advance for your help!
phitat is offline   Reply With Quote
Old 02-02-2012, 11:02 PM   #2 (permalink)
Gameroom cash: $254267
View sarsman45's Photo Gallery
The ballast is in watts, not in the light range output. You are running either a 35 or 55 watt system, which helps provide the initial surge and continued power to the bulbs. The answer is yes, you can throw in 5000K bulbs in your setup.
The output of 4300k and 5000k is not registered in our vision, so they seem very similar. 4300K is oem and the correct light output (more yellow) while the 5000K will be more or less white. Anything higher will start going blue then purple, which is a dead giveaway to cops that you are running an aftermarket setup.
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
Old 02-03-2012, 03:09 AM   #3 (permalink)
ilikecamrys
Cking's Avatar
Gameroom cash: $536685
iTrader Score: 17 reviews
View Cking's Photo Gallery
I suppose you can get pulled over for glare or something if the cop is having a bad day but I don't see how it's a red flag for anything illegal lol.
care to elaborate? just curious
5000k is a bright white while 4300 is a warm white.
In my opinion, it's up to the person on what's "brighter" but ultimately its largely due to the projector and how its adjusted.
2k8 V6 Camry SE\\55w6000kHID||3000kfogs||Work Emotion CR-ULTIMATES
||BuddyClub Coilovers||SPC Camber Bolts||TRD Dual Catback Exhaust
||Megan FrontTowerStrutBar||StopTech Slotted Rotors||PosiQuiet Pads
||Fujita ColdAirIntake||My thread!||TN lanyards!||
Cking is online now   Reply With Quote
Old 02-03-2012, 05:03 AM   #4 (permalink)
Somewhat a Lurker
Gameroom cash: $311669
View Agent556's Photo Gallery
HIDs in a car that didnt come with stock HIDs, including retrofits are illegal, at least in california. So if they're blue enough and a cop really wants to pull you over, he has a reason that he can give
2005 Camry SE V6
http://www.toyotanation.com/forum/sh...d.php?t=343592
Agent556 is offline   Reply With Quote
Old 02-03-2012, 12:48 PM   #5 (permalink)
2009 Camry SE I4 MGM
glenn14's Avatar
Gameroom cash: $339525
View glenn14's Photo Gallery
I have 35 watt ballasts and 5000k D2S bulbs with an MDX projector retrofit. Most cops up here, don;t even know what a retrofit is, neither do the inspection stations,
as I have never been rejected for a sticker mine is like an OEM setup at night no different from say a Lexus ES350 or something. Now if your putting anything higher in a reflector set up with a deep blue or purple hue, then its a dead giveaway to the cops.
Glenn
2009 Camry SE MODS:
Blacked Out Headlights with MDX D2S Retrofit,TSX-R Clear Lens, 85122+D2S Bulbs, G2 Red Painted Calipers, W.T.Floor Liners, Rosen Navi. GEN6.5 Chrome Wheels, XD Digital 35 watt ballasts, H11 Wire Harness, Megan fstb.
glenn14 is offline   Reply With Quote
Old 02-03-2012, 03:25 PM   #6 (permalink)
Gameroom cash: $133200
View xx03Camryxx's Photo Gallery
This...it's illegal to put a HID bulb into a halogen setup.
xx03Camryxx is offline   Reply With Quote
Old 02-03-2012, 11:28 PM   #7 (permalink)
Sevn86's Avatar
View Sevn86's Photo Gallery
So many ppl here have cars like that and it drives me crazy!
Sevn86 is offline   Reply With Quote
Old 02-03-2012, 11:49 PM   #8 (permalink)
ilikecamrys
Cking's Avatar
Oh i see..
I know that if its a little blue they MIGHT be able to give u something for it but if its 4300k - 5000k then it should be fine.
But HIDs in SUVs or beams that aren't aimed =
Old 02-04-2012, 02:05 AM   #9 (permalink)
Gameroom cash: $418500
View tengiday's Photo Gallery
Yup, it's illegal, but a retrofit is still better than pnp HID kits in terms of morality. A retrofit can be approved if it can pass both photometric and physical tests. Unfortunately, no one has submitted their headlights for the tests since the cost is probably too high.
2008 Toyota Camry LE I4 - Modifications as if they come with the car.
- TRD wheels, TRD suspensions
- OEM replica navigation with iGo/Tomtom/...
- Folding LED signal side mirrors with JDM control switch
- HID retrofit headlights with S2000 projectors and Denso ballasts, fog lights
tengiday is offline   Reply With Quote
Old 02-04-2012, 01:07 PM   #10 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
Retrofit is the only way to go. On my 2008 Hybrid, I am using Bi-Xenon Morimoto projectors with clear lenses and 4300K H1 bulbs. This is the low-beam cut-off:
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 02-05-2012, 09:55 PM   #11 (permalink)
View DarkCaLiBeR's Photo Gallery
Question
hi guys I have a question can I put a 55watt bulb in a 35watts ballast
DarkCaLiBeR is offline   Reply With Quote
Old 02-05-2012, 11:26 PM   #12 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Yes you can do that but:
1) Your beam pattern will have uneven "light spots".
2) The bulb will burn out much faster (like in a few months).
3) The color temperature won't look as advertised (e.g. 6000K will look more like an intense 5000K).
4) You will create even higher heat in your headlight housing.
Old 02-06-2012, 12:23 AM   #13 (permalink)
He said 55W bulb with 35W ballast. What you said is true for the opposite.
Old 02-06-2012, 12:27 AM   #14 (permalink)
Some possible outcomes depending on the bulbs and ballasts:
1) The bulb will filcker.
2) The ballast may fire on, and shut off after a while.
3) The ballast won't ignite at all.
4) Some misfire at the beginning; try to turn it on again and it works.
5) It may work normally with the brightness like a 35W bulb.
Old 03-29-2012, 05:08 AM   #15 (permalink)
glenn14's Avatar
Or most people onthis site go to www.theretrofitsource.com and email or talk to Matt.
They have everything you would need.
Glenn
2009 Camry SE MODS:
