2010 engine air filter change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2012, 07:56 PM   #1 (permalink)
View lenjack's Photo Gallery
How do I replace the engine air filter on my 2010, 4 cylinders?
With photo(s), please.
Thanks
Any car problem can be fixed with a large enough hammer!
lenjack is offline   Reply With Quote
Old 02-06-2012, 08:05 PM   #2 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
If it's the same as my 2008, it's just 2x 10mm bolts holding it on there.
It's simple, this is the most basic of maintenance.
Edmond.
Edmond is offline   Reply With Quote
Old 02-07-2012, 01:06 AM   #3 (permalink)
lilajto's Avatar
Gameroom cash: $101750
View lilajto's Photo Gallery
do you know where the air filter is? if you do. there are two 10mm screw you need to unscrew. That should allow you to change it. but if you want to clean the inside and have better access. there there is a screw that you need to unscrew on the hose. loosen that up. unplug the cable. and the whole thing should come right off. then reverse this process
-lilajto
Lilajto's Update Thread
lilajto is offline   Reply With Quote
