Originally Posted by Black T
I am pretty sure that I did that step correctly. Once I have the mirror snapped back in, the corner near the heated mirror wire is the loose part.
It sounds like one of the pivot points has popped out or is broken between the mirror attachment point and the drive motor.
Check and correct, if possible.
Otherwise;
I would scrounge the local junk yard for any color mirror and swap out the drive positioning system / mirror mount. Make sure you match the correct side.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
