07 Camry TCS, VSC, ABS, Brake lights on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2012, 07:51 PM   #1 (permalink)
View igbeserk's Photo Gallery
Hey,
My 2007 Camry SE has been acting weird lately. has about 49k miles on it. Lately most of the lights that come on and go off have been staying on randomly. Usually its the brake, tcs, abs, and vsc. They'll come on and stay on but if i shut off the car for a bit they'll come on and dissapear like they normally are supposed to. Every now and then this used to happen where some of those lights would come on. Now it's been happening a lot lately. It happened last weekend even the check engine light came on i tried cutting it on and off and nothing. Drove about 30 minutes cut the car off for 5 then cut it back on and it went away.
I'm trying to figure out what's causing the issue. I can only think of a few new things that have occured. Two weeks ago I was coming back from new york, late night and I was in a rush so I was going 90-100 most of that 2 hour ride. When I got back into philadelphia I saw a mustang GT and I wanted to see if my 4 cylinder camry could keep up. So i was upshifting on my automatic from 1st to D. We kept coming to lights and I kept starting back at 1. Now I hardly do that but when I used to do it even on my old lexus es300. I would shift around 3-5 rpms. and especially on the camry it would shift smoothly. That night though it seemed to take a while for it to shift to the next gear and drop the rpms back down. So i don't know if me doing that was the cause of these lights constantly coming on.
Also, i had HID lights put into my car about two weeks ago. I already had the ballast and all but my previous HID bulbs had burned out so I was using the stock bulbs til i finally decided to buy new ones. I don't know if these new HID bulbs are causing some power failure or something to cause those lights to come on. I don't have a relay for the HID's i tried a relay when i first installed them and the lights wouldn't come on so I removed it and just upped the fuse a little for the headlights and fog lightsto make sure i don't burn something out.
I also tried jumping my ford probe a few weeks back tried to do it a few times. I doubt jump starting another car would be the cause of it.
Anyway these are the things that I can think of that may effect it. Lately i've been letting my car sit i've been driving my 91 ford probe since i'm trying to learn how to drive stick. So i don't even touch my cam much but I try to keep it well maintained. i mostly use the cam for long trips now or trafficy days on my way to work. Sometimes i don't let it warm up i don't think i need to since its fairly newer and in better shape plus doesn't take long to warm up.
Sorry if i'm rambling guys, any help would be most appreciated I don't have an OBD2 scanner to see what the read out would say but i'll try to borrow one from my friend.
The only time i can remember those lights coming on and staying on was in a previous post I had but turned out it was a loose battery cable on the battery. Since someone had rear ended my car and the body shop was working on it they had removed the battery cable. when they were done they put it back but forgot to tighten it. So it was acting really crazy.
igbeserk is offline   Reply With Quote
Old 02-10-2012, 02:26 PM   #2 (permalink)
any ideas fellas? i'm going to try an OBDII scanner tomorrow.
Old 02-10-2012, 05:59 PM   #3 (permalink)
View aagitch's Photo Gallery
I would take it to the dealer and see if they can pull any codes.
2010 Camry SE 2.5L-35% Front & 20% Rear, Hollandia 700 Series Comfort sunroof
aagitch is offline   Reply With Quote
Old 02-11-2012, 06:21 PM   #4 (permalink)
Yea i will try to do that. free time i will have to be able to go is in about two weeks. i used my friends obdii and i got P0500 which is the vehicle speed sensor.
So i have to look into that.
Old 02-12-2012, 04:28 PM   #5 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
when you installed the hids where did you put the ballast? If you have the ballast anywhere near the ABS system, that maybe what is causing those lights to come on. Because the ballast are giving off a wave signal interfering with the ABS system. The ABS pump is the part on the right side near the antifreeze reservoir.
It looks like this:
http://www.ebay.com/itm/ABS-PUMP-TOY...#ht_4262wt_905
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is online now   Reply With Quote
Old 02-12-2012, 05:10 PM   #6 (permalink)
I actually have the right side ballast tied to that i believe. its behind the washer fluid and before the coolant reservoir correct? if that's what it is then yea it's tied there with zip ties to hold it in place. Maybe that is the issue but its odd when I had HID bulb installed before it gave me no issues one bulb went out and i would say since october or so i've been without hid's until about 3 weeks ago when new ones came in.
I've reset the code with the obdii and checked other info through that everything so far seems to be ok. But, i'll try to see if i can place the ballast somewhere else.
It looks like this:
http://www.ebay.com/itm/ABS-PUMP-TOYOTA-CAMRY-07-08-09-/130610241176?pt=Motors_Car_Truck_Parts_Accessories &vxp=mtr&hash=item1e68fa1e98#ht_4262wt_905
Old 02-12-2012, 05:23 PM   #7 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
yes its the part that looks like the link i gave you, wire several small pipes coming out of it. Some other members on here had the same problem with that. They had the ballast too close to that and caused the light to come on, and plus it could damage the ABS pump too later down the road. Try to find a spot somewhere far away from that.
Old 02-13-2012, 10:14 PM   #8 (permalink)
thanks for the info man. i'll move it away from the pump tomorrow and then i'll drive it around hopefully i don't get the p0500 code again nor those lights. will do a tranny flush soon also.
