Those with Ultra Racing RSB BEWARE - Page 4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2012, 10:15 AM   #46 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $611924
View BlackCamSe's Photo Gallery
Gen6
Originally Posted by knightslugger View Post
honest guys, a little gusseting of those stock mounts and that 23mm bar will be fine.
By strengthening that bracket you will be creating a new weak link. If the bracket can't give who knows what else will. All of that extra force will be transferred to the subframe and I don't want to see whats gonna give.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 09-07-2012, 11:29 AM   #47 (permalink)
knightslugger's Avatar
View knightslugger's Photo Gallery
I disagree. the weak link is just moved up to the next stronger part. Those bolts are massive. if the frame can't handle it, you're using the car in a manor that it is not designed or modified enough to be used in. You've found the limit in which you can use the car, right? Are you satisfied that it's the best the car can do?
i doubt it. I wouldn't be anyway...
It can be much much more, with just a little more effort.
If the new part snaps, then it's evidence. but what broke on the car is a red herring for getting rid of the 23mm bar.
2009 Red Camry XLE V6
knightslugger is offline   Reply With Quote
Old 09-07-2012, 01:42 PM   #48 (permalink)
View rule62's Photo Gallery
My new weakest link is the rigid brake line that got bashed when the bracket failed. Part #47321-06090 for those that are interested. cheap enough part, but I think I may have to drop the gas taknk to get it routed properly.
Truth is, I got the 23mm rsb for S's & G's. I don't track my car or drive it that spiritedly. I can live with the stock rsb. Red herring (perhaps). So far we've got 3 examples of the part failing in this thread. I simply don't want to go through any additional hassle like this if the part fails again.
rule62 is offline   Reply With Quote
Old 09-07-2012, 03:33 PM   #49 (permalink)
well to be fair, only one was documented well enough, and was a rusting part to boot. it's integrity was already compromised.
Old 09-07-2012, 04:20 PM   #50 (permalink)
fairness agreed
Old 09-13-2012, 05:36 PM   #51 (permalink)
Togue superstar
t3chnique's Avatar
iTrader Score: 6 reviews
View t3chnique's Photo Gallery
I'm assuming you don't have coilovers? You must be pushing the car pretty hard around the corners tho for this to happen, props to you. First time I've heard of someone breaking those pieces.
This is actually a common problem in most of the older Civics and last generation Integras when the rear sway is upgraded to a large piece. Thus a company called ASR developed a subframe brace, which counters this very problem. Check out the pics below.
This is what a RSB looks like bolted up with no reinforcement.
Here, you see the brackets attached to the subframe brace, the large silver part in the middle.
Now, I'm currently working with a fabricator to make me a custom one-off pieces so I don't suffer from the mishap you did
Just suspension and cosmedics.
t3chnique is offline   Reply With Quote
Old 09-13-2012, 07:09 PM   #52 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
she was on coils for maybe 15-20K miles with the rsb. Haha. Let us know how much it costs to get that piece fabed and maybe ill be interested
Old 11-12-2012, 12:07 PM   #53 (permalink)
View camry0707's Photo Gallery
Gen6 ultra racing sway bar for 07 camry
i have a 07 camry le and about 3 months ago i replaced my stock sway bar which is 16mm with the ultra racing 23mm. two days ago i realize that because the bar is so rigid and heavy it broke the metal plate that supports the sway bar and stabilizer links. this plate is bolted onto the chasis on the left and right side, and from the looks of it, its not that thick. this was a nightmere for me. Is there anyone out there that has experienced this; let me know. I'm really thinking of going back stock or trying the ultra racing 19mm.
camry0707 is offline   Reply With Quote
Old 11-12-2012, 12:24 PM   #54 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $601050
View hardtopte72's Photo Gallery
Moved your post to the existing thread. I have had one for less than that. I plan on gusseting the mount to make it stronger.
My Toyota List:
1982 Corolla SR-5 Hardtop 1JZGTE R154
2005 Corolla CE Manual 1ZZFE
2009 Camry LE Auto 2AZFE
If I helped out in any way please hit the blue Thanks button on my post.
hardtopte72 is offline   Reply With Quote
The Following User Says Thank You to hardtopte72 For This Useful Post:
camry0707 (11-12-2012)
Old 11-12-2012, 12:41 PM   #55 (permalink)
the same thing happened to me 2 days ago. it was a nightmere. i have to replace the 2 brackets.
Old 11-12-2012, 07:59 PM   #56 (permalink)
Senior TN Member
nuchieboy's Avatar
Gameroom cash: $320099
View nuchieboy's Photo Gallery
Gen6
i had the 19mm and one bracket snapped. I replaced both for like $100 and took me about 45 mins of labor
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 11-12-2012, 08:38 PM   #57 (permalink)
damn. if the 19mm is snapping the plate also i dont know what to do. its looking like i am going back to stock.
Old 11-12-2012, 09:52 PM   #58 (permalink)
Senior TN Member
nuchieboy's Avatar
Gen6
i am also running h&r springs and 19s in the summer so that could also factor in
Old 11-12-2012, 10:07 PM   #59 (permalink)
i am planning on lowering with hr springs and i am getting some 19s for next summer. how are the hr springs? do you like the stance and ride comfort?
Old 11-12-2012, 10:31 PM   #60 (permalink)
Senior TN Member
nuchieboy's Avatar
Gen6
the h&r's ride nice...sporty but not uncomfortable. My sunroof rails do make a little more noise now that its cold here in jersey when the chasis flexes. Still love the ride
