Atb ever since i fixed the connector issue i have not had anymore problems i think whats happening is the connector is barely touching and when you go over a bump it's as if you were unplugging it and plugging it back in I I bent the tabs and I don't have any more issues you may want to try cutting the end off and connecting it directly to a power source I didn't do it that way because i want to be able to remove it when i want to
Sent from my LG-MS770 using AutoGuide.Com Free App
Also ppl the manual is wrong as for the return to normal mode after start.Confirmed it today when i had called them for my issue .The guy told me it saves the last mode.
@Caprise - I dont want to cut the ends just in case weapon r gives a replacement.But tried one more thing, I removed the pins from the connector(weapon r connector) (did not cut them) & directly inserted them in to the right slots in the obd.
Still the issue persists.
Double check to make sure the connection is solid and re-learn the i-throttle to see if that helps or tape an extra wire up to those connection prongs from the i-throttle and tap into a direct source just to see if the issue persist, if it does RMA the unit for a new one.
2011 Camry SE V6 Fully Loaded w/o Navi
BC Racing Coilovers with custom 7/4kg Springs
23mm UR Racing RSB
18x8.5in Candy Red Work Emotion CR Kai's
I think u'll be better off returning that unit for a new one. The longer u wait the harder it'll be to get a replacement. My connector is kinda wobbly too but never lose contact or reset itself.
The Following User Says Thank You to GT-R For This Useful Post:
Holy crap. Just found out this exist. This would be perfect for my 2010 V6. My 2011 Mustang GT was tuned and had zero throttle lag, I miss that so much.
So the verdict on the Weapon-R for a Gen 6 V6 is all good?
My response is an emphatic "YES!!!"
The throttle booster doesn't completely solve for the Toyota-tuned, MPG-focused transmission shifting but it does help tremendously.
__________________ 2007 Camry V6 SE, Blue Ribbon Metallic, UR Strut/Sway Bar, K&N SRI, Magnaflow mufflers, H&R Springs, TSW Nurburgring 18x8, Reus Sound System, More
if you find a better price, email them and they will price match it for you.
23mm UR Racing RSB
Guys, I have read that there is a cable from the unit that needs to be attached to the brakes as a safety so that every time the brakes are used it breaks the unit's circuit and avoids acceleration. Does anybody know how that is hooked? Where is the brake cable?
BTW mine is a 2009 Camry 2.4l (Australian).
that blue wire? its suppose to hook up to your reverse signal. so when you shift it into reverse the throttle sensitivity goes back to stock instead of tapping the gas and you floor the car.
23mm UR Racing RSB
Can you please advice in maximum detail possible how that blue cable should be hooked?
2009 Toyota Camry Grande 2.4L (Australian)
