gen6 replacement lense forming - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2012, 11:45 PM   #1 (permalink)
lalojamesliz's Avatar
View lalojamesliz's Photo Gallery
Does anyone here do it? My current headlight lenses's are still not as clear as I would like so I'm interested in making my own by following the DIY thread on hidplanet but if someone already has made some then I would rather just buy a set. Anyone know?
07 V6 SE: blue LED dashboard , rx330 Retro, modded intake
08 5.7L Sequoia
69 mustang
lalojamesliz is offline   Reply With Quote
Old 11-28-2012, 11:46 PM   #2 (permalink)
I already tried restoring them
08 5.7L Sequoia
69 mustang
Old 11-28-2012, 11:58 PM   #3 (permalink)
Gameroom cash: $138715
View LUVLEXUS101's Photo Gallery
no
03 Max modded //sold
07 Camry XLE i4, all stock.
LUVLEXUS101 is offline   Reply With Quote
Old 11-29-2012, 12:23 AM   #4 (permalink)
I was looking at my headlights before I came to work and they look like they might not be very easy to do on the DIY thread the headlights used were in the shape of a long brick. Damn
08 5.7L Sequoia
69 mustang
Old 11-29-2012, 12:39 AM   #5 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $600050
View hardtopte72's Photo Gallery
Definitely going to be a pain to do.
How about pics of your lights? You could always try eBay and buy some TYC lights and either swap your projectors to them or swap the lenses from them. TYC seems to be the best quality.
My Toyota List:
1982 Corolla SR-5 Hardtop 1JZGTE R154
2005 Corolla CE Manual 1ZZFE
2009 Camry LE Auto 2AZFE
If I helped out in any way please hit the blue Thanks button on my post.
hardtopte72 is offline   Reply With Quote
Old 11-29-2012, 01:02 AM   #6 (permalink)
I did that to make lens for the foglights on my maxima. It was actually relatively flat, yet it took me 6-7 pulls to get it done. Either open the lights and clean the inside or just get new lights amigo. Def not worth the trouble.
Old 11-29-2012, 02:35 AM   #7 (permalink)
Thanks man
08 5.7L Sequoia
69 mustang
Old 11-29-2012, 02:42 AM   #8 (permalink)
On a picture they don't look bad but the difference with the sharpness of the cutt off and color band when I have the lense on and off is huge. I recently went to a auto show in Arizona when I was visiting family and I was looking ay the lenses on some of the cars and was amazed how clear they were. I guess ill just keep them the way they are.
08 5.7L Sequoia
69 mustang
Old 11-29-2012, 07:44 AM   #9 (permalink)
gator1939's Avatar
Gameroom cash: $316785
View gator1939's Photo Gallery
I may not understand the whole situation, but can't you just buy new lenses from the dealer?
gator1939
2B1ASK1
gator1939 is offline   Reply With Quote
Old 11-29-2012, 08:43 AM   #10 (permalink)
I've heard the color loss can be attributed to the curvature of the headlamp lens.
Old 11-30-2012, 12:34 AM   #11 (permalink)
gator1939
I don't think so but I'll check
08 5.7L Sequoia
69 mustang
Old 11-30-2012, 07:27 AM   #12 (permalink)
gator1939's Avatar
If not the dealer, then a body shop. I'm positive that if you cracked one in an accident, the dealer or a body shop would be able to replace it with something from some supplier.
gator1939
2B1ASK1
Old 11-30-2012, 04:39 PM   #13 (permalink)
Gameroom cash: $170900
View kitacamry's Photo Gallery
There seem to be PLENTY of them on Ebay...
16th ride, 1st Toy: 05 J-vin Camry LE i4....Enjoy your Toy
kitacamry is online now   Reply With Quote
Old 12-01-2012, 09:00 AM   #14 (permalink)
View louie1086's Photo Gallery
Fogging/Yellowing of the lenses is due to oxidation of the plastic from exposure to the elements and can be easily fix by using a scratch-remover product. Think about how white plastics turn yellow over time. The same is happening here.
I typically use Meguair's Sractch X 2.0 and have had pleasing results. IMO much cheaper and easier than replacing headlights.
Rides:
96 Emerald Green Metallic Camry LE (R.I.P)
09 Classic Silver Camry LE
louie1086 is offline   Reply With Quote
Old 12-01-2012, 12:19 PM   #15 (permalink)
i <3 Toyota
HiTek21's Avatar
Gameroom cash: $199039
View HiTek21's Photo Gallery
Vacuum forming lenses is hard and a hit or miss unless you had the right equipment and know how. I tried making some custom shrouds for projector retrofit before. It took maybe 12 attempts before I got a decent set. I either heated the plastic too much or not enough so it would pop or not form properly. I also noticed some little bubbles in the plastic when it cooled (it didn't matter because I painted them). I also spent about $200 in building the vacuum forming box and different types of acrylic and ABS plastic. I'm not sure how UV resistant that acrylic i was using is either, it might yellow faster than the plastic in the Toyota lenses.
I caution about ebay headlights, while they say they're OEM they vary in quality. When i was doing projector retrofitting for my Tacoma I tried 3 different sets and all three had their differences from the Toyota lights. First one was an unknown but said OEM. This one was absolute junk, the tabs and everything were paper thin and felt cheap. Not to mention the turn signal diffuser had broken loose in shipment and scratched up the lens inside. The second set was TYC which was pretty good overall, tabs were as thick as the Toyota ones but I'm not sure of the halogen beam output. I was marking the reflector cut off patterns and it looked a bit uneven/crooked on the wall (might have been the bulbs used though). The third set was some Anzo brand which was about as good as the TYC ones but more expensive because they were black housing (I'm really not good with spray painting)
If it were me, I would check one of the online Toyota Parts suppliers and buy a set from them. It will probably put a small dent (probably $200-250 per light) in your wallet but probably cheaper than going to your local dealership.
2007 Speedway Blue Tacoma X-Runner 1GR-FE - URD Exhaust, URD Y-Pipe, TRD CAI, TRD Short Shifter, SS swaybar kit, TTC Traction bars, TL Projector retrofit, and more
2010 Magnetic Gray Metallic Camry SE V6 2GR-FE - TRD Dual Catback Exhaust, JL Stealthbox, Alpine PDX-M6, UR Strut Bar
HiTek21 is offline   Reply With Quote
