Strut Recommendation for softest ride for 02 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2013, 11:36 PM   #1 (permalink)
View dgreen1064's Photo Gallery
Hi,
My sienna died after 240K so I now have an 02 Camry V6 with 146K on it and I believe the struts are original?? They look pretty rusty. I have arthritis in my back and want to get the Camry to ride as smooth/soft as possible. I replaced the Goodyear tires with Michelin defenders and that helped a lot with road noise and small stuff. I'm thinking the next place to look is the struts, but the car doesn't bounce over bumps. In fact, it's actually rather stiff. Handles well on curves -- almost like it has performance struts? I've read the struts can be worn out even if the car isn't bouncy. There has to be something I can do because my wife's 03 Prius rides a smoother than the Camry, and my 99 Sienna was smoother yet. One suspension guy told me that Monroe sensa tracs should give it a softer ride. But will these be softer than OEM? I don't care about handling. I want the car to soak up the pot holes so I don't feel all the bumps going up my back. Any help would be greatly appreciated!
dgreen1064 is offline   Reply With Quote
Old 01-14-2013, 12:16 AM   #2 (permalink)
Moderator
Zmon's Avatar
Gameroom cash: $442455
View Zmon's Photo Gallery
Maybe Monroes.
You could try using smaller rims, that will def help.
2007 Camry SE Mag Grey
MDX Retrofit w/Black Series lens, Osram CBI D2S, K&N SRI, Rosen G3, LED interior/tags
Zmon is offline   Reply With Quote
Old 01-14-2013, 07:01 AM   #3 (permalink)
LEXUS ES
speedkar9's Avatar
View speedkar9's Photo Gallery
Gen5
Is your Camry an SE? If so try swapping the suspension for one for an LE or XLE, since SE suspensions are much stiffer.
2005 Lexus ES330
1999 Toyota Solara SLE V6
speedkar9 is offline   Reply With Quote
Old 01-14-2013, 09:25 AM   #4 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1387108
iTrader Score: 7 reviews
^ Stole my words lol.
What model is it? I was going to say the same as Speedkar.
2002 Camry SE 1mz-fe "Snow White" - Track/Summer Car
1998 Subaru Legacy 2.5GT Limited - Winter/Rainy Day Car
Old 01-14-2013, 09:32 AM   #5 (permalink)
View dgreen1064's Photo Gallery Strut Recommendation for softest ride for 02 Camry
Sorry, I should have mentioned it is an LE. Running 205/65 R15 for tires already. Thanks!
Old 01-14-2013, 11:17 AM   #6 (permalink)
LE and XLE Have the same struts and springs... So Have the struts looked at, may need to be replaced. There's not many aftermarket choices for our cars as far as struts go though.
Old 01-14-2013, 03:09 PM   #7 (permalink)
Gameroom cash: $170800
View kitacamry's Photo Gallery
Check your psi.....if it's 35+ that would make for a stiffer ride...try 30psi if that's the case...29psi is what is recommended on the door jam
16th ride, 1st Toy: 05 J-vin Camry LE i4....Enjoy your Toy
kitacamry is online now   Reply With Quote
Old 01-14-2013, 06:43 PM   #8 (permalink)
Yes, Monroe site only lists OESpectrum struts for 2002 year. Doesn't look like sensa traks are even available. Any body have any experience with OESpecrum struts?
Tags
ride comfort, struts
